Home > Technical (L322) > Replacing the rear diff?
gizze
My RR has been running really nicely, now at 128k miles, and the only issue with it (at the moment, it is a RR after all) is a whine from the rear diff from 40mph under load.
I have been looking for a low mileage used rear diff to become available and found one from a 60k mile car so I have ordered it and it should be here tomorrow.
I was just wondering if there is anything I need to know before changing it over?
Should you disconnect the battery etc. when doing work like this so it doesn't effect suspension level sensors? Or leave it connected?
Has anyone done one of these and know how long it should take?
Any special tools needed?
Sorry to ask what probably sound like basic questions, but I'm a clothing retailer not a mechanic. But my father in law has a garage and does lots of Isuzus 4x4s etc. and will probably ask me all these questions when I get there, so thought it best to ask beforehand.
It is a regular diff and not the e-diff btw.
Thanks all! Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452691 2nd Oct 2017 10:12am
here is the howto from RAVE for earlier models
http://www.fullfatrr.com/gallery/albums/userpics/10584/diff~0.pdf
Can't be that much different Wink .
Post #452694 2nd Oct 2017 10:25am
gizze
Cheers for that Joe, looks like it can done during lunch break!! Very Happy Porsche 911 (996)
Post #452698 2nd Oct 2017 11:19am
Might also be worthwhile getting new bushes for the diff, while you have it off, and of course some lovely new rear axle fluid. Make sure you can undo the filler plug before undoing the drain plug and draining it though. .
Post #452701 2nd Oct 2017 11:41am
gizze
Yeah, good idea.
I always check I can get the fill plug out before undoing the drain plug on everything. You only make that mistake once! Laughing Porsche 911 (996)
Post #452703 2nd Oct 2017 11:55am
fisha
those few pages dont seem to mention the halfshafts out (or did I just not see that bit ? ) They'll need to come out the sides of the diff too.
The process doesn't look much different from the freelander 2 method. I was able to change the diff in that on a driveway using just a couple of jacks and axle props.
Hardest part is supporting the weight of the diff. They are heavy. for the freelander, I made a wooden bracket that spread the support of the jack to a few places on the diff, which kept it much steadier. V8 or else ...
Post #452755 2nd Oct 2017 6:45pm
gizze
Cheers for that.
I have a ramp and decent jack to drop it onto, so that should help.
I used partsgateway, and asked for any rear diffs from cars with less than 60k on them and got one for £330 delivered, so fingers crossed it is OK. Porsche 911 (996)
Post #452763 2nd Oct 2017 7:32pm
GraemeS
Australia
Pulling the half-shafts back far enough with the hand-brake cables still attached was quite a struggle when my son and I swapped mine's open diff with an e-diff.
I made-up a lever for the initial release of the half-shaft clips.
Post #452767 2nd Oct 2017 8:08pm
gizze
Thanks for that. Porsche 911 (996)
Post #452768 2nd Oct 2017 8:13pm
@ fisha, it is there, Page 2 items 12-14 and an image Thumbs Up (only talks about one though Wink) .
Post #452801 2nd Oct 2017 10:52pm
fisha
Ah ha! so it is! I was looking for pictures where the halfshaft slides right into the diff. Didn't realise the driveshafts just bolted onto the diff a bit like a propshaft. V8 or else ...
Post #452825 3rd Oct 2017 8:28am
GraemeS
Australia
No they don't! Page 2 steps 17 and 18 refer to the half-shafts but no picture other than of the lower wishbone bolt to be removed.
Post #452834 3rd Oct 2017 11:13am
We are all wrong!
Page 2, Steps 12-18 Laughing .
Post #452863 3rd Oct 2017 4:44pm
