Home > Technical (L322) > l322 air suspension HEADACHE!
Page 3 of 3 <123
miggit
Just had a thought Shocked Big Cry Ouch!
Has the relay for the pump been changed? Only I know it's supposed to be changed with the Wabco pump, and if it's got burnt contacts then it will not be giving the full beans to the pump. And it will run slow, and your tank will fill up slowly and your dash will BONG you and the screen of doom will read your walking! A poor earth to the pump will do the same thing.
If it is the ECU then your looking at around £150 S/H or £300 new, it is alot , but not as bad as it could be! But I'd look in to everything else first before going down that route, cos you know it'll need coding Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #299596 18th Dec 2014 1:41am
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Take a read of my thread
Mine hasn't played up once since (touching wood quickly - lol)
http://www.fullfatrr.com/forum/topic18252.html
Post #299755 18th Dec 2014 11:42pm
OzTom
Austria
Gallery or reservoir pressure?
Hi,
I experience pretty much the same suspension fault symptoms on my 2006 L322, i.e. almost always ca. 30 secs after staring the car the dreaded “bing” and suspension fault warning. At this point the compressor shuts down. Haven’t had yet access to a hoist to check for minor air tube leaks but a few things are weird.
First, when requesting either an off-road or easy access movement before the “bing” the lifting or lowering works fine and the system does not send a compressor shut off signal.
Second, using the IIDTool, the system pressure quickly rises after starting and the reservoir valve opens to 100% from ~ 10bar (which would indicate an air tight reservoir) but once “binged” and the compressor shut off the (IIDTool “gallery”) pressure drops to atmosphere within ca. 5-10 secs.
Since the pressure sensor is mounted on the reservoir the IIDTool is showing the reservoir pressure and not the gallery (as I understand was used on earlier models) where is the pressure drop occuring the IIDTool is displaying?
Is an electrical problem more likely, since the EAS does work before cutting out? I.e. do vehicle movements wiggle a faulty harness? But this contradicts the pretty constant time interval before cutting out?
Also, it only used to throw failure code “pressure increase too slow” C1A20-64 and recently added “air supply component failure” C1131-92. And yes, I did service the compressor last year with new piston seal and dryer dessicant. Unless I mucked up, but seeing the pressure rise w/o fault after a complete air drain, I would assume that service went ok. Btw, how long does it take to fill a completely drained system back up to ca. 12bar?
Any ideas of enlightment out there?
Tom (2006, L322, TD6)
Post #453612 10th Oct 2017 6:27pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
wow pal , this thread is 3 years old , suggest you open a new one to get a better response
Post #453621 10th Oct 2017 7:46pm
GraemeS
Oz Tom, the compressor is failing. Changing heights requires less pressure than that used to replenish the reservoir, which only occurs once the target height has been reached. The 5 minute delay is typical of the pressure increase too slow fault.
Post #453634 10th Oct 2017 9:19pm
OzTom
Austria
Air supply valve faulty?
Graeme...ta,
could that be a faulty valve within the air supply unit? But why is the so-called gallery pressure quickly decreasing after compressor cut out?
What do you mean by 5 min delay typical of compressor failure?
Cheers, Tomo
Post #453668 11th Oct 2017 5:32am
GraemeS
The compressor exhaust valve might not be sealing thus preventing proper pressure.
Is your pressure sensor on the reservoir side of the reservoir valve or on the compressor side? Later systems have it on the reservoir side - perhaps only from MY07 (uses the Terrain Response system from the Discos & RRS). The system exhausts the pressure side of the compressor when it stops, presumably so that the compressor isn't having to start against a high pressure next time.
Post #453686 11th Oct 2017 8:29am
OzTom
Austria
Pressure sensor location
Graeme,
won't have a chance to look it up today, but since the LR workshop manual released in 2002 already depicts the sensor directly screwed into the reservoir, I assumed that this is the case.
Tomo
Post #453705 11th Oct 2017 12:32pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
air suspension..
juat a thought, have you checked your battery/alternator, 9/10 times, inactive suspension alarms related to low system voltage, after i changed my alternator, it cured a multitude of alarms on my 2004 td6, just sayin'.....
Post #453888 12th Oct 2017 11:28pm
OzTom
Austria
Battery charge
Yep, the devil is fully charged with relatively new (6 months) battery
Post #454015 14th Oct 2017 12:09pm
OzTom
Austria
SOLVED: it was a faulty compressor
hmm, although I did replace the piston ring, cleaned exhaust valve and replaced the desiccant I eventually replaced the compressor (for ca. USD 300 incl. shipping and taxes via the Chinese "Amazon") and bang - all fine, no error messages.
Post #457504 16th Nov 2017 1:43pm
miggit
Whistle That happened to me.. rebuilt the compressor and there was very little improvement, in the end I just bit the bullit and brought a new one, instant cure!
The trouble is that when the compressor shows signs of needing a rebuild, it has already gone past the rebuildable stage... it needs to be done before the piston ring wears out, otherwise the cylinder becomes scored and the whole unit is useless Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #457565 16th Nov 2017 11:32pm
stuart_2006
Just adding another voice to the "air hose has chafed on the chassis" party. Car doesn't drop overnight, but had a hissing sound for around 30 seconds after switching off, and the occasional 'normal height only' bong message. 6mm blue hose has chafed on the chassis around 4 inches from where it comes out of the spare wheel well heading towards the valve block. Splice connector on order.
Post #601044 18th Jul 2021 2:21pm
Page 3 of 3 <123
