Home > Technical (L322) > TPMS....again
Page 2 of 3 <123>
Paul J.
I had the same problem last winter - where the valve stem was corroded and snapped when I was checking the tyre pressure. Quite unnerving at the time.
All were replaced under warranty. The service chap at the dealers indicated that I was not the first to suffer this problem, and did not quibble over replacement. THe new ones have a different stem.
Notwithstanding what is written earlier, it is my understanding that new sensors have to be coded to the car. AFAIK the bit about running above a certain speed for a certain number of minutes applies to already coded wheels that have been, for example, switched to a different axle, although I stand to be corrected.
Paul
Post #45486 11th Jan 2011 12:00am
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
TPMS has fixed itself - magic.
Took plenty of start cycles but the finance director assures me all is well.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #45613 11th Jan 2011 9:37pm
I spent the first 6 months of ownership with the VSE TPMS system showing a fault. It drove me potty but then I just seemed to block it out...
Eventually the fault was diagnosed as a faulty NSR sensor, which ironically is what I had pointed out in the first place from an error message that never showed again afterwards.
This is one of those options I'd happily live without. If I am driving and I get a puncture I think I will notice. Thanks. Never needed it thus far in my life and the 2 cars that had it, it played up. Worthless gizmo to me.
Rant over. Discovery 4 HSE
Post #46409 17th Jan 2011 11:36pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
I switched off my tyre pressure fault light I got fed up changing the corroded valves I just changed then to standard valves and reprogramed instument pack
Very easy when you have access to autologic diagnostics Thumbs Up 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #46555 18th Jan 2011 10:46pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Ed, can I just check with you what happened.... you installed a new TPMS valve into your 08 RR and it eventually was recognised by the CPU without any programming by the dealer? In other words no dealer programming is needed for new valves?
Reason I ask is that my dealer took days trying to program a new sensor, using gallons of fuel driving up and down the road to no avail. Now it is working ok, but from what you say this has happened without the efforts of the dealer.
My next problem is that I am changing wheels and tyres (another saga in itself; downsizing from 22 to 20) and the indy broke 2 valve stems. I can buy two new sensors, but the question is: should I just change the valve stems so that I use my existing sensors that are already programmed into the vehicle, or can I just put in the 2 new sensors and they will eventually be picked up by the CPU.
Thanks, any inputs appreciated
Post #60230 13th Apr 2011 10:22pm
They are self configuring - no dealer input required - after 10 minutes or so of driving, the car should recognise the new valves.
Post #60233 13th Apr 2011 10:51pm
taskam
Then the dealers are on a scam here.....two of them told me reprogramming is needed at a rate of half to one hour labour charge. Thanks fo replying.
Post #60246 14th Apr 2011 6:53am
EDWARD757
Hi,
Sorry for the delay in response but yes, no dealer input. The car was driven around a few times and suffice to say it did not reprogramme instantly but give her a week or so and it should!
Best of luck,
'03 BMW M3 - SOLD
Post #60250 14th Apr 2011 8:19am
taskam
OK I'll bung in the new sensors, Thanks for your reply. Agree with the view that these things are more Censored trouble than they're worth.
Post #60251 14th Apr 2011 8:26am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Ummmm, I have just specced this to my new car as it has no spare only a can of "stuff" to repair the tyre! Wonder if I should delete it in view of all the posts about the problems 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60264 14th Apr 2011 9:42am
Having had TPMS "warnings" since I got my car 4 weeks ago, I'm going to have the bl@@dy thing disabled!
Complete nightmare and total waste of time! Censored Got - 2017 SDV8 Autobiography in Loire Blue
Post #60268 14th Apr 2011 10:04am
I guess they are charging you for driving round until they are recognised....
Maybe just push them a bit and ask them what 'reprogramming' entails ?
Post #60412 14th Apr 2011 10:56pm
I just swapped my wheels for a new set complete with new TPMS valves.
The first 15 minutes driving showed no faults, but then the ECU obviously sent the error message to the dash and now the blinking light is on again. Censored
I have tried endless driving over 12mph for over 15 minutes, even been to Manchester and back and it STILL hasn't reset itself. Big Cry
TPMS is just a total bag of Shat if you ask me. I don't want to take it to the damned Dealer just to get a light switched off. Censored
Does anyone have a DIY option that's better than me sticking a piece of black tape over the light so I can't see it anymore? Shocked Discovery 4 HSE
Post #64576 18th May 2011 8:45pm
Paul J.
Could you pull the fuse supplying the TPMS to 'reset' the system, then try again with getting the system to recognise the new sensors?
Worth a try?
Paul
Post #64602 18th May 2011 10:55pm
adam, try moving the wheels around , we did this once and it solved the problem..
Post #64613 19th May 2011 8:30am
Page 2 of 3 <123>
