![]() | Home > Technical (L322) > TPMS....again |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
TPMS has fixed itself - magic.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
I spent the first 6 months of ownership with the VSE TPMS system showing a fault. It drove me potty but then I just seemed to block it out...
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
I switched off my tyre pressure fault light I got fed up changing the corroded valves I just changed then to standard valves and reprogramed instument pack
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Ed, can I just check with you what happened.... you installed a new TPMS valve into your 08 RR and it eventually was recognised by the CPU without any programming by the dealer? In other words no dealer programming is needed for new valves?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
They are self configuring - no dealer input required - after 10 minutes or so of driving, the car should recognise the new valves. |
Then the dealers are on a scam here.....two of them told me reprogramming is needed at a rate of half to one hour labour charge. Thanks fo replying. |
Hi,
OK I'll bung in the new sensors, Thanks for your reply. Agree with the view that these things are more |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Ummmm, I have just specced this to my new car as it has no spare only a can of "stuff" to repair the tyre! Wonder if I should delete it in view of all the posts about the problems 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Having had TPMS "warnings" since I got my car 4 weeks ago, I'm going to have the bl@@dy thing disabled!
I guess they are charging you for driving round until they are recognised.... Maybe just push them a bit and ask them what 'reprogramming' entails ? |
I just swapped my wheels for a new set complete with new TPMS valves.
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
Could you pull the fuse supplying the TPMS to 'reset' the system, then try again with getting the system to recognise the new sensors?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
adam, try moving the wheels around , we did this once and it solved the problem.. |
