Home > Maintenance & Mods (L322) > WAX OILING The Beast
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Today Its been a good day to WAX OIL the main sub frame of one of the Rangies - she's done 57,000 miles and behind the Front Bumber the sub frame was showing a bit of surface rust - which had to go - so no point in doing half a job - as usual just go all out and get her back to prime condition.
I think most of you will agree the LR322 is far better than any LR405 in terms for styling - I know this because we have both - and the LR 322 is just styled far better.
so a few pics from today:
If a jobs worth doing - do it the best you can
Hope this helps anyone wanting to wax oil their Rangie - a point worth noting: Wax Oil the whole chassis It will pay off in years to come - I have always Wax Oiled them from brand new - helps with the MOT's later in life
One last thing - if ever you take a Bolt Out - Just put a brand new one in - I cant stand folk who use the bolts/screws from before - New ones are far better.
Post #454948 22nd Oct 2017 6:31pm
pld118
impressive... you must have a tolerant partner... to allow you the time to do all that! Laughing
Post #454950 22nd Oct 2017 7:04pm
GGDR
Yeah and that's some workshop!
You look well equipped to pop the engine out to do the subframe Very Happy
Bow down Bow down Bow down Cheers, Greg
Post #454952 22nd Oct 2017 7:12pm
EmiratesA380
Aircraft is my first passion - then theirs the Rangies - I have to know how everything works - this one was 2 months old from new and I had to take her apart to find out what made her tick - I have that type on mind.
Warranty never comes into it - They build them I take them apart - and I can honestly say they are better than when they were in the show room
Have fun Fella's on here - Remember your Rangie is only as good as the time you put into her - Look after them and they will run forever
I ve said this time and time again - we sometimes know more than LR dealers know - FACT
Post #454954 22nd Oct 2017 7:21pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I would also add that if you take a bolt out and replace it always coat it in copper grease! 👍
Jim
Post #454971 22nd Oct 2017 8:43pm
EmiratesA380
Jim
I note what you say - but just be careful - MOST bolts are Torqued up to a correct value and if you use cooper grease then these WILL come lose and the TORQUE wrench WILL OVER TIGHTEN in every case as theirs no friction - which a Torque wrench needs !
Just think about what BOLT / NUT you are doing - as most of the time TORQUE Bonding is paramount
ie: Brake caliper mounting plates / Brake Calipers / Diff Bolts / Transfer Box bolts - these never use Copper Grease
But I know what you mean Thumbs Up
Post #454973 22nd Oct 2017 9:06pm
jim4244
I have to ask, but why are you still using Waxoil? There are far better rust treatment and corrosion treatments on the market that are vastly superior to Waxoil?
Have a look at my weapon of choice - https://www.dinitroldirect.com/4x4-vehicle-rustproofing-guide/
Jim 👍
Post #455023 23rd Oct 2017 11:36am
EmiratesA380
I give up - better things to do
Post #455024 23rd Oct 2017 11:41am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Dinitrol is hardly new. My father, a chemist, decided on Dinitrol in 1964 to treat his new A40 Countryman.
I'm currently clearing huge piled of MightComeInHandy from the front of our garage. I'm hoping in another week or so, I might reach the A40 and have a look at how well it has done. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #455063 23rd Oct 2017 7:13pm
jim4244
I didn’t say it was new? I said that it was better and having used both Waxoil and Dinitrol on many of my vehicles I find that Dinitrol is far superior to Waxoil.
Jim
Post #455067 23rd Oct 2017 7:47pm
