Home > In Car Electronics (L322) > rear camera
p38arover
Australia
Had I seen those cameras before I did my conversion, I'd have gone that route. Confused
Why didn't you wire the camera input into the rear view camera input in the TV tuner module in the rear compartment? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #455311 25th Oct 2017 11:08pm
Balloonengineer
Yes, the camera does automatically turn on when you put in reverse. This is done automatically by enabling it in the CCF files. This is shown in pic 5 where it has "take care in manoeuvring" the top of the image.
Works nicely in the dark too, although I have upped the wattage of my reversing lights.
Best wishes
Glen
Post #455317 25th Oct 2017 11:46pm
Balloonengineer
Answer for P38 rover
This is because that facility I believe is only available up to 2004 MY (prob up to around 53 plate) with a blue plug on the TV module and a different head unit, as far as my research goes it won't work 54 plate ish onwards....
The later ones from 2005 MY (54 plate) have a different wiring (MOST) system. There is a grey plug on the top with lots of spare connections, would be great to find out if any of those are aux or video inputs. Anybody here worked out what the spare grey connections are for?
Best wishes
Glen
Post #455319 25th Oct 2017 11:54pm
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
This looks really good to me and I'm going to give it a punt. Just wondering, would the picture angle be better/different if I tried to mount a similar type camera under the rear spoiler like the 2005 on models?
Post #455374 26th Oct 2017 4:08pm
Balloonengineer
I don't think it works that well under the spoiler. The angle of the boot lid means it masks the last foot or so up to the bumper, so if you need it for tight parking or in my case reversing up to a trailer without smashing the bumper, I wanted to see all the way to the ball/bumper
Best wishes
Glen
Post #455385 26th Oct 2017 7:20pm
p38arover
Australia
Aha! I don't understand the plate number system. It's much easier for us foreigners when you use model years. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #455418 26th Oct 2017 10:48pm
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
you see that red wire hanging out of the yellow connectors.
This red wire can be used to power the camera from front to rear. (and avoid extra wires though the tailgate)
2A fuse recommended
I recommend you DON'T use the reversing light wire, so the camera can still operate when in Drive/manuourving.
Connect it to Acc or Ign or cigar lighter feed
Post #462660 29th Dec 2017 8:52pm
Nifty190
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
you have guide lines ....s;lightly jealous
Post #462661 29th Dec 2017 9:14pm
Andy K
lines come from the camera.
Post #462662 29th Dec 2017 9:16pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
So, does this mean my 53 plate should be plug and play? As in, just get a reversing camera and all the necessary connections are in the boot ready to connect?
Or am I being a bit optimistic here?
Post #462702 30th Dec 2017 12:08pm
miggit
^ Your car is easier to install a camera, but it is a little more involved than just plug and play...
http://www.fullfatrr.com/forum/topic24647....ra+install Yesterday I couldn't spell Engineer... Today I are one!
Post #462714 30th Dec 2017 2:08pm
rodp
That's me stumped then.
Post #462721 30th Dec 2017 3:27pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Or you could do what I did and fit a dash cam in the rear, the angle would be better too.
I have since modified the use also with added cameras in the horse box while on the move, inside to see how they travel and at the back of the trailer. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #462750 30th Dec 2017 7:34pm
miggit
Bud it's not rocket science, I managed to do it!!
There are a number of places that you can fit a camera.. I went for a BMW X5 camera that replaces the number plate lamp... but having seen how the camera is positioned and type used in this post, I think I'd use this method... for a kick off the cameras are half the price!!
The only really tricky bit is adding the 3 connections to the 2 plugs on the TV tuner... the rest is wiring up a relay! I used a solder type... a, because I'm a tight git and hate spending unnecessary dosh, and b, a solder joint is better than a crimp... but go with which ever you are most comfortable with!
I can help with descriptions and possible diagrams on 'how to' anything you are not sure about, But the only thing that I might find difficult is pictures, as I no longer have an L322... But I do have limited access to a pals that I did! Yesterday I couldn't spell Engineer... Today I are one!
Post #462768 31st Dec 2017 6:55am
