Home > Technical (L322) > Vano cover seals
handyM
England 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Vano cover seals
Hi just need to know if a gasket sealant is needed on replacing new Vano cover seals.
any help please
Post #455806 31st Oct 2017 10:11pm
holidaychicken
If you are talking cam covers then yes you need to apply the correct sealant to either side of the half circle cut outs at the rear and either side of where the upper timing cover join is st the front.
If it's upper timing. Overs then no you don't
It shows a pic in Rave or have a look at Beisan site at the m62 procedure.
I'm away or I'd send you a pic and a link to the correct sealer
Post #455816 1st Nov 2017 8:40am
handyM
Vanos cover seal
Thanks for the reply holiday chicken
the cover seals are the solenoid seals to engine m62
Post #455817 1st Nov 2017 9:00am
handyM
cover seals for the solenoids (LuD000010), it says in rave
to lubricate seals .I presume with just engine oil ?
Post #455818 1st Nov 2017 9:02am
holidaychicken
Arr those ones, you don't have to but i would. beisan site says to use sealer on them. i would clean the sealing face as best you can and the outside of the solenoid and apply a thin layer of sealer on the sealing face of the seal and just around the inside of the bore of the seal, not loads but just enough to give it a bit of help to seal as the sealing face may not be ever so easy to clean and the outside of the solenoid could be a bit rough.
i used a little pick tool to remove mine, they may feel stuck but i put a little pick tool into the bolt holes in the seal and worked on each one in turn a little at a time.
There are a couple of non return valves behind there as well that can be replaced but you need a long m10 metric fine bolt to pull them out and a special socket to remove the solenoid
Post #455886 1st Nov 2017 8:40pm
handyM
vano cover seals
thanks for the reply holidaychicken need to replace them this weekend due to oil leak
Post #455930 2nd Nov 2017 10:32am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I just replaced mine which we spewing oil, after following holidaychicken's advice of putting sealant on they're dry as a bone
Post #455935 2nd Nov 2017 11:49am
