![]() | Home > Technical (L322) > Vano cover seals |
handyM Member Since: 24 Nov 2015 Location: stockport Posts: 19 ![]() ![]() ![]() |
Hi just need to know if a gasket sealant is needed on replacing new Vano cover seals.
Thanks for the reply holiday chicken
cover seals for the solenoids (LuD000010), it says in rave
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Arr those ones, you don't have to but i would. beisan site says to use sealer on them. i would clean the sealing face as best you can and the outside of the solenoid and apply a thin layer of sealer on the sealing face of the seal and just around the inside of the bore of the seal, not loads but just enough to give it a bit of help to seal as the sealing face may not be ever so easy to clean and the outside of the solenoid could be a bit rough.
thanks for the reply holidaychicken need to replace them this weekend due to oil leak |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I just replaced mine which we spewing oil, after following holidaychicken's advice of putting sealant on they're dry as a bone |
