![]() | Home > Wheels & Tyres > General Grabber AT3 |
| RichTDV8 Member Since: 16 May 2010 Location: Berkshire Posts: 57
David
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766
Thank you for that Rich!
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
I used to run Generals, they will do 60k miles and fantastic off-road - had 3 sets but have Just bought a full set of Cooper 285/50/20's as I couldn't get Generals in this size - they certainly look very capable !
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
run cooper LTZs on my disco, also seem very good. There is nothing that can't be fixed with a hammer😜😜
Agreed, but unfortunately due to EU rules the LTZ's are no longer available in the UK - they have ceased supply to the UK, only old stock is now being sold until they run out. The replacement is the AT3 Sport which also is available with a higher speed rating, as the LTZ was very low compared to the General Grabbers speed rating. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| SABAI4SABAI Member Since: 30 May 2017 Location: Aargau Posts: 13
| ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341
Any news on the snow capability? |
Tried 2 times ....never as good as a real Winter tire but i could get everywhere i needed...... |
| PH77 Member Since: 14 May 2018 Location: Munich Posts: 4
I fancy with the same tire size 275/55r20 AT3s, but worry about the difference on the speedometer. Due to the larger circumfence compared to the original 255/50r20, is there the need to adapt the speedometer? It would indicate a 6% lower speed than it would on the original tires.
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482
The 245/45r20 will be way too small compared to the original tyre size.
Absolutely correct, I actually meant 275/45r20, which should be almost the same as the original, but still smaller ...
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Just this week fitted four AT3's to replace Cooper Zeon's and they are steets ahead on noise and especially wet grip , I knew the Zoen's were poor just not how much. I ran the AT back in Scotland and loved them so I wanted to go back to them but they are not available anymore and thought the AT3 might be too road and winter biased but I'n not so sure now , time will tell butI certainly won't be able to test for their snow ability |
