![]() | Home > Wheels & Tyres > General Grabber AT3 |
RichTDV8 Member Since: 16 May 2010 Location: Berkshire Posts: 57 ![]() ![]() ![]() |
David
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Thank you for that Rich!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
I used to run Generals, they will do 60k miles and fantastic off-road - had 3 sets but have Just bought a full set of Cooper 285/50/20's as I couldn't get Generals in this size - they certainly look very capable !
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
run cooper LTZs on my disco, also seem very good. There is nothing that can't be fixed with a hammer😜😜
Agreed, but unfortunately due to EU rules the LTZ's are no longer available in the UK - they have ceased supply to the UK, only old stock is now being sold until they run out. The replacement is the AT3 Sport which also is available with a higher speed rating, as the LTZ was very low compared to the General Grabbers speed rating. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
SABAI4SABAI Member Since: 30 May 2017 Location: Aargau Posts: 13 ![]() ![]() ![]() |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
Any news on the snow capability? |
Tried 2 times ....never as good as a real Winter tire but i could get everywhere i needed...... |
PH77 Member Since: 14 May 2018 Location: Munich Posts: 4 ![]() ![]() ![]() |
I fancy with the same tire size 275/55r20 AT3s, but worry about the difference on the speedometer. Due to the larger circumfence compared to the original 255/50r20, is there the need to adapt the speedometer? It would indicate a 6% lower speed than it would on the original tires.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1475 ![]() ![]() |
The 245/45r20 will be way too small compared to the original tyre size.
Absolutely correct, I actually meant 275/45r20, which should be almost the same as the original, but still smaller ...
Just this week fitted four AT3's to replace Cooper Zeon's and they are steets ahead on noise and especially wet grip , I knew the Zoen's were poor just not how much. I ran the AT back in Scotland and loved them so I wanted to go back to them but they are not available anymore and thought the AT3 might be too road and winter biased but I'n not so sure now , time will tell butI certainly won't be able to test for their snow ability |
