Home > Maintenance & Mods (L322) > Troubleshooting canbus error?
Danwilderspin
Hi all - my ff as you may have seen has the dreaded air suspension inactive fault. After diagnosis I am getting canbus error come back from it... I have a canbus stereo mod that been in since April couldn’t see it being this so disconnected it and I retrofitted the gateway module some time ago so will do the same for that, so where do I start to look then? Is this common? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456069 4th Nov 2017 12:41am
Danwilderspin
Right been up on this glorious rain now I have all ‘aftermarket’ canbus devices disconnected and off the canbus lines ... still get the same air suspension inactive faults... any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456078 4th Nov 2017 10:04am
fisha
Are you clearing all errors ?
The air suspension faults that the EAS raise get logged within the air suspension ECU and the headlight ECU.
If you only clear the air suspension ECU, then at the next start up, the headlight ECU reports to the car the suspension error it has stored.... which in turn the air suspension ECU records for itself again.
You have to clear both the air suspension ECU and the headlight module as well. V8 or else ...
Post #456126 4th Nov 2017 2:28pm
Danwilderspin
Cleared all the faults - now just have a fault stored in abs for steering angle sensor is this the possible cause? Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456158 4th Nov 2017 6:11pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I had all sorts of those fault codes, eventually I replaced the steering angle sensor and it fixed them all.
Post #456310 6th Nov 2017 2:59am
Danwilderspin
Did you manage to take the shortcut of removing the four bolts without removing the dash? And did the lights go out without recoding or did it need coding first? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456312 6th Nov 2017 8:11am
Danwilderspin
Also aside from no traction or abs is it causing any harm driving it as is? It blows up and drops on startup ok and isn’t on the bump stops from what I can tell Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456337 6th Nov 2017 1:53pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I had this and it was my ABS module that had gone squiffy. Replaced it and all has been well.
What I would do first though is to reinitialise the steering angle sensor with the IIDtool, you’ll have to this anyway if you replace the ABS module as it stores info from the sas.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #456453 7th Nov 2017 12:24pm
Danwilderspin
Ok - shall I check the abs plug? Also can I drive like this? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456464 7th Nov 2017 2:50pm
UK Marine
Have a look for corrosion in the plug and any dampness, and as you've probably noticed the suspension works ok on the road. The only thing was I couldn't adjust the suspension, but mine was intermittent only failing when the engine temps got up to normal and the heat was expanding a soldered joint causing the fault. It's very common apparently ______________________________
Simon
Post #456466 7th Nov 2017 2:58pm
lounge_on_wheels
Dan, I got the 4 bolts out without tsking the dasjha aprt via short cut, but a sod of a job for access, ended up taking the dash apart to refit as I was wrooried about cross threading the upper bolts, acces is a sod, once dash out it was a quick refit.
I used iidtool BT to renew the sensor recoginition and then cleared all faults,
Cheers,
Post #456675 9th Nov 2017 3:47pm
Danwilderspin
Can it be coded without iid tool I have pa soft and I have inpa? Anyone done it completely without dash removal? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456684 9th Nov 2017 4:53pm
Danwilderspin
Also is it hard to get in the right place or is there a master spline?
As a side note I’m guessing the sat nav gets data from the steering sensor as it is great in a straight line but it won’t work out you’ve turned off it then has to catch up Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #456999 12th Nov 2017 9:59am
Danwilderspin
https://www.landyzone.co.uk/land-rover/ste...es.312092/
Followed this and cleared the faults took around 90 mins now we are good again! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #461925 23rd Dec 2017 3:49pm
