![]() | Home > Maintenance & Mods (L322) > Troubleshooting canbus error? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Right been up on this glorious rain now I have all ‘aftermarket’ canbus devices disconnected and off the canbus lines ... still get the same air suspension inactive faults... any ideas? Current stable:
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Are you clearing all errors ?
Cleared all the faults - now just have a fault stored in abs for steering angle sensor is this the possible cause? Cheers Current stable:
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I had all sorts of those fault codes, eventually I replaced the steering angle sensor and it fixed them all. |
Did you manage to take the shortcut of removing the four bolts without removing the dash? And did the lights go out without recoding or did it need coding first? Current stable:
Also aside from no traction or abs is it causing any harm driving it as is? It blows up and drops on startup ok and isn’t on the bump stops from what I can tell Current stable:
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I had this and it was my ABS module that had gone squiffy. Replaced it and all has been well.
Ok - shall I check the abs plug? Also can I drive like this? Current stable:
Have a look for corrosion in the plug and any dampness, and as you've probably noticed the suspension works ok on the road. The only thing was I couldn't adjust the suspension, but mine was intermittent only failing when the engine temps got up to normal and the heat was expanding a soldered joint causing the fault. It's very common apparently ______________________________
Dan, I got the 4 bolts out without tsking the dasjha aprt via short cut, but a sod of a job for access, ended up taking the dash apart to refit as I was wrooried about cross threading the upper bolts, acces is a sod, once dash out it was a quick refit.
Can it be coded without iid tool I have pa soft and I have inpa? Anyone done it completely without dash removal? Current stable:
Also is it hard to get in the right place or is there a master spline?
https://www.landyzone.co.uk/land-rover/ste...es.312092/
