![]() | Home > Maintenance & Mods (L405) > Land Rover OEM flange tow bar question... |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288 ![]() ![]() ![]() |
I’ve also been thinking of having this towbar fitted.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Happy to help there |
Some "real world" photos for you. There is one piece left to fit (which is should arrive from Dan @ Duckworth's tomorrow) and that's a revised cover that fills on the gap behind the new receiver hitch and between the two silencers. There's a big plastic infill there on yours now, but it needs to be replaced with one that fits around the receiver. Personally, I like the look of it; it gives it a purposeful look ![]()
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1422 ![]() ![]() ![]() |
Is it just a case of removing the rubber bung, inserting the bar of the towbar unit and then a pin through a hole in the receiver and the towbar, with a clip through the pin (i.e. not threaded like the bolt that holds the 322 detachable towbar in place)? Subject to any anti-clunk device you are adding. So a 5-minute job to take the towbar off/put it back? Only Range Rovers since 1988 |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
@Red Merle: Majestic and good looking ffrr in the carport - and really nice with the dog: King of the boot |
Many Thanks Red Merle - exactly what I was looking for. Very grateful. 2016 SDV8 AB |
@ CS: Absolutely, it's really that easy (it takes less than a minute to do without the anti rattle device!).
Hope you don't mind a follow up question but how much should I budget for a dealer fit of this setup including electrics? 2016 SDV8 AB |
Not at all.
Thanks - appreciate it. 2016 SDV8 AB |
Just on the issue of rattling, I was looking at the LR instructions (in the 'manuals' section of the LR website) for this towbar on MY17 and there was an anti-rattle bolt to be tightened to 55Nm I think which seemed to be near/behind the pin that holds the bar in place. You (Red Merle) didn't mention that, does yours not have it? Only Range Rovers since 1988 |
CS: No, there’s no anti rattle bolt on mine |
Maybe have a look at www.ownerinfo.landrover.com and work through the menus to the section on fitting these towbars to RRs. Both 2016 and 2017 models show the bolt, so Q if a word with your dealer might produce something? I know what you mean about the rattling being annoying and worrying, especially in the light of the problems with the Discovery which led to accidents and eventually a recall. One instinctively thinks movement must be undesirable. Only Range Rovers since 1988 |
I don 't think it's a safety issue by itself as this form of tow bar is extremely common in the USA, where they all seem to be affected by this very same issue. It seems to just be the nature of the beast. However, they are also they country that provides the after market solutions.
