Home > Maintenance & Mods (L322) > Adaptive dynamics fault
Page 1 of 3 123>
Webbie
About a year ago I resolved this fault by soldering a broken wire at the top of a shock. The fault is now showing up on my dash again. So I guess I had better do the "upgrade harness". Has anyone fitted the upgrade harness and if so:
• How is the lower end attached to the wiring loom?
• Is the lower end easily accessible, or deep in the engine bay?
• Is it a suitable job for an entry level DIY'er?
Post #454938 22nd Oct 2017 5:25pm
here's a six page that should help to inform you,
http://www.fullfatrr.com/forum/topic22949.html ... - .- -.
Post #454940 22nd Oct 2017 5:30pm
Webbie
Thanks Stan, it's just where it joins the main loom I need to be aware of now.
Post #454945 22nd Oct 2017 6:02pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Just chop it mate, bullet connectors
Post #454955 22nd Oct 2017 7:26pm
Webbie
Thank you Mr T, Surgery planed for next Saturday morning
Post #454959 22nd Oct 2017 7:31pm
Deegs64
United Kingdom 2011 Range Rover SE 4.4 V8 Barolo Black
Hi everyone. New to the forum so hope I’m doing this right. I have the same issue with adaptive dynamics fault. Couldn’t see anything obvious so I will look in more depth tomorrow when it’s light but I wondered if anyone could tell me if I sort the possible broken wire will the fault light disappear or do I need to takenitbtondealer for them to remove the fault light. Thanks in advance
Post #459226 1st Dec 2017 9:16pm
GGDR
Fault will clear once the wiring's sound.
. Cheers, Greg
Post #459230 1st Dec 2017 9:46pm
Deegs64
Thanks mate. Really appreciate the quick reply. Could I also ask, do I unwrap the tape from the wires to check for the break if it’s not obvious? What about where it joins the main harness? Nervous about goingbpastvthatvpoibt. Apologies if I’m asking basic stuff but I’m not the most practical. Thanks again
Post #459231 1st Dec 2017 9:53pm
GGDR
No probs Deegs.
Check out this thread, including a good youtube video I found:
http://www.fullfatrr.com/forum/post452532.html#452532
The break is usually very obvious, you'll need a Torx driver to remove the shock covers.
Then remove insulation, the break is usually around the area where the wire enters the shock tower.
Is a very satisfying fix once done.
Good luck,
Greg Cheers, Greg
Post #459234 1st Dec 2017 10:10pm
Deegs64
You sir are a gentleman. Thanks Greg for your advice. I managed to take covers off earlier but couldn’t see anything obvious. I will look a little more in depth tomorrow during daylight and let you know how I get on,was too cold out there with my torch and I wasn’t sure wether or not to unwrap the tape around the wires before they enter the tower through the black covers. Thanks again for your help. I take it that it’s not likely to be anything else?
Post #459237 1st Dec 2017 10:19pm
GGDR
Ah too kind - it's all about sharing the knowledge which is the amazing thing about this forum. I came as a complete newbie a year ago and I've learnt so much. The least I can do is contribute back, as everyone does here. A few jokes fly around too which tops off all the advice.
Could it be anything else? 95% it'll be a break near the tower. The thread I linked to covers that. This thread actually talks about the loom end which some people have had issues with. But as I said, 95% chance it's tower end. But could be either side to trigger the fault.
Unwrap the insulation, feel along the wire for the break and if nothing felt, check the other side.
Solder or connector join, start her up and check to see if the fault is gone.
Once fixed, re-wrap with black tape and put the kettle on!
You'll find the Terrain Response features are unavailable while this fault is active too.
. Cheers, Greg
Post #459241 1st Dec 2017 10:30pm
Deegs64
Cheers Greg. I will let you know how I get on. Thanks again
Post #459242 1st Dec 2017 10:34pm
Deegs64
Greg sorry. Me again. Last time mate. You said unwrap the insulation and feel along the wire. Does that mean it may not be an obvious broken wire and could be a break within the insulation which I will only be able to tell by feel? Thanks mate.
Post #459246 1st Dec 2017 10:50pm
GGDR
Hi Deegs, - well I guess feel and look closely.
If you look at that Youtube video it's a good example of when you're looking for. In that case it's a visible break of the wire including the wire's own insulation.
But it's a small wire so just a good study for damage.
The reason I said 'feel' is that the wire on mine was not split completely in two, but when I ran my finger nail along, I felt a 'nick' in the wire's own insulation. The insulation was damaged but not broken completely. When I bent the wire back on itself kinda hinging it on the partially split insulation, the copper inside was a clean break.
Hopefully makes sense.
. Cheers, Greg
Post #459265 2nd Dec 2017 8:27am
Deegs64
Hi Greg. Update as promised. All working now so thank you very much. It was the osf that had a break. Used a connector as no soldering gear which made it a little difficult refitting the cap but all works again now. The grommet i could only get in half way, will that be ok or will I need to revisit? Tbh both sides the wires are in a bit of a state so think I will send for the new upgraded harnesses. Any recommendations where to get them from? Many thanks again mate and if ever you are in the corby area, I owe you a pint. ðŸ‘ðŸ»ðŸ‘ðŸ»ðŸ‘ðŸ»ðŸ‘ðŸ»
Post #459305 2nd Dec 2017 2:10pm
Page 1 of 3 123>
