Home > In Car Electronics (L322) > IDDTOOL
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
IDDTOOL
Sudently the IIdtool stop working and a local repair shop said they only could connect by first disconnection
The front head lights. This is a walk around they have used before on l322s. Have you heard about this, and is there a known way to fix the IIdtool connection.
Br Rags -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #459266 2nd Dec 2017 9:02am
is that the connection via the obd port, if so are there any pins that are bent... ... - .- -.
Post #459270 2nd Dec 2017 9:12am
Norway
Hi, that's correct, no bent pins. -03V td6
Post #459340 2nd Dec 2017 6:15pm
Is it a BT (bluetooth) version?
Has it been dropped? Send GAP an e-mail and they will explain how to open the unit and check if the BT connector has been “jarred/come apart” Thumbs Up
Post #459342 2nd Dec 2017 6:20pm
Norway
Yeah, it's the BT version. -03V td6
Post #459354 2nd Dec 2017 7:49pm
Drop Patrick @ GAP an email and he will help you Thumbs Up
Post #459368 2nd Dec 2017 9:33pm
