![]() | Home > Technical (L322) > Which oil type 4.4 TDV8 ? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
You can check it cold, if you open the bonnet, but it’s supposed to be done warm👍🏻 There is nothing that can't be fixed with a hammer😜😜
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35693 ![]() ![]() |
i'm quoting from the owners manual so dont shot the messenger, the 3.6 is checked cold, the 4.4 must be at working temperature.. ... - .- -.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Greg, if you can't read oil level with cold engine, try opening bonnet; go to service menu ;check oil; exit service menu; press cancel on steering wheel (cruise control) ; go back to service menu and check oil. this can be used to check oil level with worm engine and without having to wait 15~20 min. to do so - taking in to account that not all oil may have drain to the bottom of the sump. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
oh wow great hack Nino, thanks!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3829 ![]() ![]() ![]() |
Nino’s tip with picture … press twice quickly, ( with bonnet open )
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 827 ![]() ![]() |
Out of curiosity, the new spec is 935B
