Home > Technical (L322) > Which oil type 4.4 TDV8 ?
Page 3 of 3 <123
GGDR
Another:
Overheard in Waitrose: 'Mummy, why have you bought Waitrose Essentials Carrots?'
'Don't worry, Rufus, they're for the horses'
Rolling with laughter Rolling with laughter Cheers, Greg
Post #459451 3rd Dec 2017 5:35pm
You can check it cold, if you open the bonnet, but it’s supposed to be done warm👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #459497 3rd Dec 2017 10:19pm
i'm quoting from the owners manual so dont shot the messenger, the 3.6 is checked cold, the 4.4 must be at working temperature.. ... - .- -.
Post #459503 3rd Dec 2017 10:34pm
nino_nino
Greg, if you can't read oil level with cold engine, try opening bonnet; go to service menu ;check oil; exit service menu; press cancel on steering wheel (cruise control) ; go back to service menu and check oil. this can be used to check oil level with worm engine and without having to wait 15~20 min. to do so - taking in to account that not all oil may have drain to the bottom of the sump.
Post #459718 5th Dec 2017 7:49pm
GGDR
oh wow great hack Nino, thanks!
. Cheers, Greg
Post #459765 5th Dec 2017 11:12pm
Baltic Blue
Nino’s tip with picture … press twice quickly, ( with bonnet open )
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #459801 6th Dec 2017 9:34am
Rambles
Out of curiosity, the new spec is 935B
Is this much better than the 934?
And is there an oil generally better than the AFL ?
Post #459842 6th Dec 2017 6:41pm
Page 3 of 3 <123
