Home > Maintenance & Mods (L322) > Drivers door handle in the cold.
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
How many people pulled in the exterior drivers door handle durring the last few days of freezing weather and found it stuck solid ? I know some one who had to revert to the passenger door for entry as this was ok. I used to have this problem with my previous FFRR. Is there a reason why it always seems to be the drivers door ?
Post #460469 12th Dec 2017 8:37am
its a common problem on the early FFs Dave...water gets trapped in the door lock and then freezes...it happened to mine and i took the lock out and dried it and packed loads of grease in to repel any water...some have been successful with wd40.. ... - .- -.
Post #460471 12th Dec 2017 9:11am
markcartlidge
Mine went this morning. Is it broken? Internal handle still triggers unlock bt nothing happens with the external;-(
Post #460483 12th Dec 2017 10:04am
wait until it gets warmer and then see.. ... - .- -.
Post #460485 12th Dec 2017 10:07am
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Re: Drivers door handle in the cold.
Indeed - Monday morning climb across
Must be the area Rolling with laughter 2009 Stornoway Grey Vogue TDV8
Post #460492 12th Dec 2017 10:43am
markcartlidge
Working fine now. FQZ000041 £37ish from shatstone ayl. Q. to do or not do
Post #460502 12th Dec 2017 11:20am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
GT85
Like WD40. But also contains ptfe. Great for squirting into locks and preventing ice up.
Post #460572 12th Dec 2017 4:48pm
