![]() | Home > Maintenance & Mods (L322) > Drivers door handle in the cold. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
its a common problem on the early FFs Dave...water gets trapped in the door lock and then freezes...it happened to mine and i took the lock out and dried it and packed loads of grease in to repel any water...some have been successful with wd40.. ... - .- -.
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Mine went this morning. Is it broken? Internal handle still triggers unlock bt nothing happens with the external;-( |
wait until it gets warmer and then see.. ... - .- -.
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
Indeed - Monday morning climb across
Working fine now. FQZ000041 £37ish from shatstone ayl. Q. to do or not do |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Like WD40. But also contains ptfe. Great for squirting into locks and preventing ice up. |
