![]() | Home > Technical (L322) > Oil filter housing help M62 4.4L V8 Petrol |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Just changing the oil filter and there is no centre spindle in the housing, is this a problem? Normal? am I in trouble |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Did it come out with the old filter? |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
It should look like this.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 400 ![]() ![]() ![]() |
I've got a spare oil filter housing if you need one. Current:
Hello, thank you all for your replies!
Hi - Yes, it's got the centre column. Does £28 including postage sound reasonable? PM me if you're interested. Current:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
BUY IT ! That’s half what I paid |
Changed the oil again today and fitted this - thank you David - she's pulling like a train again!! |
Nice easy fix |
RupertRR Member Since: 21 Jun 2011 Location: Baldock, Hertfordshire Posts: 26 ![]() ![]() ![]() |
Just to add my two-pence-worth if I may, I did an oil and filter change last week in my fatty - (M62 4.4 petrol) and every time I started up from cold afterwards the oil pressure warning light stayed on for a couple of seconds before extinguishing. The oil level was bang on the maximum mark on the dipstick (as it always is) and before the oil change the oil light had always extinguished immediately on startup.
That is correct, i always make sure the filter is seated in the bottom of the housing before screwing the cap on and i only use OEM filters.
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
This reminds me of what the mechanic at the LR dealer dound ( and showed me ) back in 2013 whenmy 4.4 Petrol was in for a service.
