![]() | Home > In Car Electronics (L322) > DVD changer issues |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
Mine needed much more of a really hard thump than a tap to free it off!
Nifty190 Member Since: 26 Dec 2017 Location: Buckinghamshire Posts: 23 ![]() ![]() ![]() |
Are we talking toffee hammer or small sledgehammer ?? |
Back end of a screwdriver whilst pressing eject, ........if that doesnt work then the sledgehammer!!
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Take it apart and clean the mechanism. The white grease used goes waxy after a while and jams it up. Use a bit of Vaseline on it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Tried that not even mechanical clicking noise or anything from it just 3 green lights, ok so do I spend the £350 or do I try to find an adapter lead for an after market changer ?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
you can try this,
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
as said before while holding the eject button in, a good bash( next to the button) or two should fix it . i had to do this a couple of times but it works ......looks like no3 slot is the problem.....i dont use 3 anymore and not had a problem with it since |
ok so i have tried everything then i got technical pinned out all outputs etc, annnndddd..... IT DEAD
