![]() | Home > Technical (L322) > Wont start even after changing the ignition switch |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
on cold days recently when i press the start button i got a click but no start, second press would start...i did get all dash lights come up though .. i've put it down to either low battery voltage or the FF stopping me from starting until the glowplugs warmed up..
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
Cheers Stan.. I was the same.. but the thing is.. it doesnt even get to that stage.. normally you would press the button and clocks come on with the cold start message when the glow plugs come on.
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
As per Stans advice , did you check connections, my 07 did the very same and connections seemed tight but i undid and re tightened them and all good. Maybe worth a try. 2015 4.4 AB
Thanks dolph34 and stan.. bizarre but I disconnected the negative terminal for 5 minutes.. connected it again.. it has reset all my settings but atleast the baby is starting.. panic over..
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Another fix with a “battery reset”..... |
glad its sorted |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
Stan if you're getting the screen etc coming on and then a click when you press the starter button it might be a sign that the starter motor is failing - that is what happened to mine. New starter motor fitted and has been fine since. Only Range Rovers since 1988 |
i did think that but it starts first time when its not below freezing, but i will keep your suggestion on file in me head.. |
On mine there is a delay if glow plug light takes a second or two to go out but no click. 2015 4.4 AB
I agree with Stan.. I have had weird stuff happening to it when the weather has been below zero.. when the temperature is in double figures its all fine..
There are quite a few threads regarding batteries with many opinions, i replaced mine recently with a 160 stg one ( battery not opinion), slightly up on CCA and ah compared to standard but others ( more experienced ) swear by LR branded ones. I had a ' cheaper ' one in my 2007 for almost two years with no issues. 2015 4.4 AB
With mine the non-starting was not temperature-related, so perhaps yours are different. The technician did say that starter motor problems seemed more prevalent in cold weather and his theory was that there was some connection with the delay while the glow plugs warmed the fuel. The problem seemed linked to overheating of the starter motor, might it get warmer during the delay until the glow plugs have done the necessary? Only Range Rovers since 1988 |
I would get a second opinion mate.. cant think of any scenario where the sgarter motor would heat up as there is no load until after the glow plugs warm up. Current:
| All times are GMT |
