Home > Maintenance & Mods (L322) > Are they taking the p**s?
Page 1 of 3 123>
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
FFRR in main stealer for a service.
They've advised I need new pads & discs on both front and rear.
Fair enough.
Asked how much this would cost and been quoted £1,845
I nearly fell off my chair.
Is this right? Sounds very expensive to me. What do I put here then?
Post #464015 10th Jan 2018 4:47pm
Paul thornton
I think if you shop around you could save around £1300!
Post #464017 10th Jan 2018 4:51pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Main dealers are notorious for their sky-high prices for things any basic mechanic can do for a fraction of the cost.
I was ripped off over £900 for the same from an independent on my Td6 when I did not know any better. I now always source the parts myself and either fit them too, or take to my local mechanic. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #464019 10th Jan 2018 4:53pm
GAC23
I've asked DuckworthDan for a price on the parts.
Looking at Duckworth's site, even including the Brake Pad Wear Sensors, the total for parts is only £645.55
- I'm not sure I've selected the right ones hence asking Dan!
Which means the stealer wants £1,199.45 in labour! What do I put here then?
Post #464021 10th Jan 2018 4:55pm
GAC23
Does anyone more mechanically minded than me - the wife says I break out into a sweat just holding a screwdriver - know how long it takes to change front & rear pads and discs? What do I put here then?
Post #464027 10th Jan 2018 5:30pm
Paul thornton
Probably a couple of hours I would have thought.
Post #464030 10th Jan 2018 5:35pm
A bit longer than that if you are going to do the job properly, clean up the calipers, guides and guide pins etc. (make sure you do this, and use brake grease on the refit to avoid squealing) Plus all the jacking up and down, wheels on and off. Rears may take longer than the fronts, due to the drums.
I guess If I was doing it on my drive, and if nothing broke (e.g. pull though brake drum pad retainers!!) allow 1 hour per wheel.
Yes, garages would probably have 20-30 minutes per wheel. .
Post #464031 10th Jan 2018 5:43pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
A thorough job would take me 3-4 hours max on my drive. That's £300 an hour labour they are charging. Rolling with laughter
Tell you what, I'll do it for £250 an hour Very Happy Wink Whistle
Seriously though, the caliper pins can be a pain on Brembo's but that aside it's a straight forward job. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #464040 10th Jan 2018 6:15pm
GAC23
Thank you.
Stealer says 5 hours at an eye watering £160 / hr plus vat.
And they’re 50%! more expensive for the parts.
Parts from Dan and a local mechanic methinks. What do I put here then?
Post #464041 10th Jan 2018 6:21pm
Paul thornton
Euro car parts have usually got decent offers on brake parts.
Post #464055 10th Jan 2018 7:25pm
GAC23
Thanks, Paul.
My FFRR is still under a LR Warranty. So need to fit OE parts.
Ordered these from Dan. Will get a local mechanic to fit. What do I put here then?
Post #464056 10th Jan 2018 7:28pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Post #464060 10th Jan 2018 7:50pm
If you’re going to replace the rear disks, make sure you put the EPB shoes into the unlatched position. The IIDTool can do this, or there’s a manual procedure that you can follow. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #464062 10th Jan 2018 8:02pm
NC_4x4
United States 2009 Range Rover Supercharged 4.2 SC V8 Java Black
I just got Pads and Rotors done yesterday. Front and rear. Came out to the tune of $1100 US Dollars at a very reputable Land Rover shop. Dealer wanted about $1400. I think you're getting ripped off.
Post #464068 10th Jan 2018 8:29pm
GAC23
Thanks.
I presume you do this before starting on them. Then put them back into ‘latched’ when you’re done. What do I put here then?
Post #464070 10th Jan 2018 8:37pm
Page 1 of 3 123>
