![]() | Home > Maintenance & Mods (L322) > Are they taking the p**s? |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I think if you shop around you could save around £1300! |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
Main dealers are notorious for their sky-high prices for things any basic mechanic can do for a fraction of the cost.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I've asked DuckworthDan for a price on the parts.
Does anyone more mechanically minded than me - the wife says I break out into a sweat just holding a screwdriver - know how long it takes to change front & rear pads and discs? What do I put here then? |
Probably a couple of hours I would have thought. |
A bit longer than that if you are going to do the job properly, clean up the calipers, guides and guide pins etc. (make sure you do this, and use brake grease on the refit to avoid squealing) Plus all the jacking up and down, wheels on and off. Rears may take longer than the fronts, due to the drums.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
A thorough job would take me 3-4 hours max on my drive. That's £300 an hour labour they are charging. |
Thank you.
Euro car parts have usually got decent offers on brake parts. |
Thanks, Paul.
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
If you’re going to replace the rear disks, make sure you put the EPB shoes into the unlatched position. The IIDTool can do this, or there’s a manual procedure that you can follow. |
NC_4x4 Member Since: 10 Jan 2018 Location: North Carolina Posts: 3 ![]() ![]() ![]() |
I just got Pads and Rotors done yesterday. Front and rear. Came out to the tune of $1100 US Dollars at a very reputable Land Rover shop. Dealer wanted about $1400. I think you're getting ripped off. |
Thanks. I presume you do this before starting on them. Then put them back into ‘latched’ when you’re done. What do I put here then? |
