Home > General > water coming in
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
water coming in
hi everyone, there seems to be some water coming somewhere on the back door, its not actually getting in the car but is more trapped between the door aperture and the body of the car, sort of underneath the rear speaker, it seems to happen when its been raining so am guessing it runnig down the door and gettin trapped....any ideas?
best andy
Post #46402 17th Jan 2011 9:49pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Mine does the same, strangely it only happens on the rear drivers side door.
Cheers
Justin
Gone - Range Rover Supercharged 2006
Post #46403 17th Jan 2011 10:05pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
And it pee's all over you when you open it.
Mine does that!!! 15MY SDV8 Vogue SE
Post #46404 17th Jan 2011 10:06pm
Sounds like a faulty outer door seal to me. Discovery 4 HSE
1993 90 Tdi
Post #46412 17th Jan 2011 10:39pm
dan_uk_1984
I've been getting this recently - this is due to the dual door seals, water gets stuck in-between the two... The water enters through the outer felt seal at the top of the door.
D
Post #46414 17th Jan 2011 10:45pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
after some heavy rain mine also dumps some water from drivers side rear door.
Never really looked at it but from what you just said dan is it worth cutting a small piece of outer lower seal away to create a drain? 2004 black Vogue TD6
Post #46417 17th Jan 2011 11:06pm
JustinP
Surely that would allow deep water in as well.
Cheers
Justin
Post #46418 17th Jan 2011 11:13pm
letsavit2
Most car doors have drains weep hole etc. there never 100% water tight, holding waterl is not good it will rust sooner or later. 2004 black Vogue TD6
Post #46421 17th Jan 2011 11:18pm
dan_uk_1984
There is already a drain hole in the bottom of the door - thats to let water out of the inside of the door. You wouldnt want to make a hole in the door seal - if you ever went through water up to the bottom of the doors you would very quickly have wet feet.
In the winter months I often have to drive through water 1-2 feet deep (any more and I go the long way round!) and certainly wouldnt want to compromise the water-tightness of the car. Especially as there are a lot of ECU's very low down in the car, under the seats etc.
Post #46425 17th Jan 2011 11:33pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
mine does this too, i read on a forum some where that its an alignment issue. apparently this is not uncommon and landrover just realign the door to sort it out. my door looks nice and aligned already though, strange. Neutral
Post #46437 18th Jan 2011 12:36am
SteveMFr
Site Sponsor
Beat me to it. Apparently not much of a re-alignment is necessary - and I believe it is 'in' rather than up/down/sideways.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46456 18th Jan 2011 9:36am
andyleeds
turns out that both my doors do it in the back, does anyone know how much it costs to get the re-aligned........?
andy
Post #46560 18th Jan 2011 9:55pm
