![]() | Home > General > water coming in |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Mine does the same, strangely it only happens on the rear drivers side door.
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
And it pee's all over you when you open it.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
Sounds like a faulty outer door seal to me. Discovery 4 HSE
I've been getting this recently - this is due to the dual door seals, water gets stuck in-between the two... The water enters through the outer felt seal at the top of the door.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
after some heavy rain mine also dumps some water from drivers side rear door.
Surely that would allow deep water in as well.
Most car doors have drains weep hole etc. there never 100% water tight, holding waterl is not good it will rust sooner or later. 2004 black Vogue TD6 |
There is already a drain hole in the bottom of the door - thats to let water out of the inside of the door. You wouldnt want to make a hole in the door seal - if you ever went through water up to the bottom of the doors you would very quickly have wet feet.
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
mine does this too, i read on a forum some where that its an alignment issue. apparently this is not uncommon and landrover just realign the door to sort it out. my door looks nice and aligned already though, strange. |
Beat me to it. Apparently not much of a re-alignment is necessary - and I believe it is 'in' rather than up/down/sideways. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 972 ![]() ![]() ![]() |
turns out that both my doors do it in the back, does anyone know how much it costs to get the re-aligned........?
