![]() | Home > Technical (L322) > Battery drain and telephone module |
| NVB Member Since: 14 May 2017 Location: Essex Posts: 103
I have been working through trying to get to the bottom of a 240mA parasitic drain that was killing my battery in a few days. I have more to check, but have so far reduced the drain down to around 90mA just by removing fuse 22, which is for the telephone module. Now I am happy to just leave it disconnected, but it has thrown the whole MOST system out, and all I get with the fuse removed is the land rover holding screen and a flashing button.
| zarnd Member Since: 22 May 2014 Location: Kent Posts: 459
Take the MOST wires out and use part of a biro tube so that they face each other and it should then work. Tape it together and it will bypass the phone module and allow everything else to work. I have had to do this for the second time today due to a water leak in the rear that looks to have taken out my Bluetooth module and had the same issue with just the LR screen and flashing orange button.
Thanks, I'll give that a go. RR History
| All times are GMT |
