![]() | Home > Maintenance & Mods (L322) > Burning oil smell |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Sounds like the common oil cooler seals , or the pipe at the back of the engine leaking that Craig mentioned on here a while back. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
I agree with Paul.
| Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30
Are they the ones that allow oil to mix in the water as ive just paid to have that job done before i left the uk
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
It’s the oil cooler itself that cracks I believe. Just doing seals won’t be enough....the oil rings on the pipes that can also be an issue shouldn’t let that much oil out......
Thanks
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
If you have just had the cooler seals done then I would be looking at the 2 orings at the back of the engine. Easy fix for next to no money. Craig has a thread on it. The orings are readily available on the net and upgraded viton rings are recommended!
Thanks will sort when i get back |
| All times are GMT |
