|  | Home > Maintenance & Mods (L322) > Burning oil smell |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545    | Sounds like the common oil cooler seals , or the pipe at the back of the engine leaking that Craig mentioned on here a while back. | ||
|  20th Jan 2018 5:00pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | I agree with Paul.
|  20th Jan 2018 5:15pm |
| Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30    | Are they the ones that allow oil to mix in the water as ive just paid to have that job done before i left the uk
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | It’s the oil cooler itself that cracks I believe. Just doing seals won’t be enough....the oil rings on the pipes that can also be an issue shouldn’t let that much oil out......
|  20th Jan 2018 5:34pm |
| Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30    | Thanks
|  20th Jan 2018 6:11pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | If you have just had the cooler seals done then I would be looking at the 2 orings at the back of the engine. Easy fix for next to no money. Craig has a thread on it. The orings are readily available on the net and upgraded viton rings are recommended!
|  20th Jan 2018 6:15pm |
| Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30    | Thanks will sort when i get back | ||
|  20th Jan 2018 9:20pm |
| Posting Rules
