![]() | Home > My Range Rover > My Remapped 2002 Range Rover Vogue 4.4 V8 |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 930 ![]() ![]() ![]() |
I thought long and hard about replacing my third brake light with a used one as this weather has started affecting the electrics through the third brake light itself. I decided against a used one and forked out for a brand new genuine one. Once the weather is dry enough, I will be using a heat gun to help me dry out the third brake like and temporarily seal it. I am also taking this opportunity to find a bodyshop local to me to see how much it will cost to get the spoiler painted and fitted. |
I can't believe it is the 2nd Christmas with my Range Rover already |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Have a great Christmas....take care |
Merry Christmas everyone, Hope you have a great one and Happy New Year |
Thank you and to you too |
Had an interesting day today. The linkage that was bodge repaired with one of those clips off of Ebay finally gave out, the clip pinged off and the linkage separated, so I guess now I will have to get the drill out |
My L322 went for its service on Saturday 30th December, I was horrified when they told me the sump plug was slightly too small and that oil was leaking badly. Guess who had the sump plug off last. Rye Performance & Motorsport! |
The Grill arrived |
Let down for the 3rd time by the mobile mechanic, I was forced into using my Range Rover. Not that it took a lot of arm twisting really. But I really didn't want to use it long distance due to the gearbox faults. However I was really impressed that I managed to get all 35 miles without trans overheat message rearing its ugly head. But it did go into trans fail safe mode though 2 thirds of the way there. But I learned that if you keep the revs below 2250 and the speed 50 or below on a steady run, you can get quite far. The only real issue I had today was with fuel. No money until tomorrow meant I was driving with under a quarter of a tank and by the time I got home, the range read 39 miles. So tomorrow I am not risking it, I am taking a fuel can to the petrol station to top up a little bit so I can drive it to the petrol station to put a decent amount in it. |
I have now ordered a brand new oil cooler (Hella). So next month I should be able to get the oil cooler pipes and then get it fitted.
Valeter was unable to clean my car on the original agreed day, this was down to the weather. So not sparkling inside yet.
The gearbox has got a lot worse, jerks roughly into drive as well as reverse now even when its not in trans fail safe, although the gear changes are still silky smooth, So now looking for a garage to do an oil change on the gearbox just to limp it enough to get it to the MOT and home. Then it will be parked up for a little while.
Got real fed up of this cold weather holding me back, I have just bought myself a freestanding patio heater. So at least I have some hope of not freezing and being in a ton of pain trying to do odd jobs on the cars. |
Absolutely devastated. I always fear MOT's and usually if the cars fail, it's on something very minor. But my Range Rover decided to be lovely and expensive!
