![]() | Home > Technical (L322) > Suspension sitting lower on one corner. No fault messages |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 ![]() ![]() ![]() |
Hi all,
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 810 ![]() ![]() ![]() |
check the condition of the height sensor connecting rod on that corner pal |
Thanks, doesn't appear to be damaged although they're a lot flimsier than I expected, I thought they'd be metal :S Should the four markers on the display all be at the same height when level? |
Thanks, I've had it up and down through the height settings and it looks a better, I'll get a spirit level on the window lines soon |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Measure from centre of wheel to wheel arch fronts should be the same and back should be the same but from memory 10mm lower loads on here also someone put a table with the distances from wheel centre and wheel base to arch very useful |
Cheers, presumably on level ground |
