Home > Technical (L322) > Suspension sitting lower on one corner. No fault messages
Hitby
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
My '08 L322 TDV8 has a definite slant towards the drivers side. The diagram on the 4x4 screen even shows the osr wheel sitting higher than the rest. I don't have any error messages displayed although occasionally (but not all the time) the car will lower itself overnight - this is normally when its not been used much so I just figured it was a low battery.
I don't suppose anyone has any ideas of how to get the old girl to sit level. It drives fine (although I feel like I'm on a wonk but that may be just placebo) and as I said, there are no error messages. It's just annoying!
Thanks in advance
Dan
Post #465815 24th Jan 2018 8:50am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
check the condition of the height sensor connecting rod on that corner pal
Post #465854 24th Jan 2018 1:33pm
Hitby
Thanks, doesn't appear to be damaged although they're a lot flimsier than I expected, I thought they'd be metal :S Should the four markers on the display all be at the same height when level?
Post #465856 24th Jan 2018 1:45pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I ve never seen those marks exact same level.
In summer i played with connectors of sensors and battery resetted and it worked.
Give it a try.
Sensors are usually worn inside not seen outside. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #465862 24th Jan 2018 2:46pm
Hitby
Thanks, I've had it up and down through the height settings and it looks a better, I'll get a spirit level on the window lines soon Shocked
Post #465865 24th Jan 2018 3:18pm
Sandyt
Measure from centre of wheel to wheel arch fronts should be the same and back should be the same but from memory 10mm lower loads on here also someone put a table with the distances from wheel centre and wheel base to arch very useful
Post #465870 24th Jan 2018 4:08pm
Hitby
Cheers, presumably on level ground Whistle
I will try and find some (live on a hill Mr. Green )
Post #465872 24th Jan 2018 4:09pm
Sandyt
http://www.fullfatrr.com/forum/topic17657....ight+table
Post #465873 24th Jan 2018 4:14pm
