Home > Wheels & Tyres > Discovery 2 wheels to L322?
Tight777
I have a set of wheels with mud terrains on from my old Disco 2, any chance they'll fit my TDV8.
It's a bit cold and damp to go outside and try?
Post #466135 26th Jan 2018 3:55pm
bishbosh10
I'd be worried about the load rating of the wheels - The L322 is a fair bit heavier than a Disco 2.
No idea about the PCD of the bolts either. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #466137 26th Jan 2018 4:37pm
verydisco
Edited: D2 wheels are not straight swaps, no. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #466141 26th Jan 2018 4:53pm
wack61
Depending on the wheel you might need different nuts , I just swapped some 18" that were available on the disco , they had black nuts but they didn't fit the 19" wheels which needed the chrome nuts
Post #466153 26th Jan 2018 6:22pm
mjdronfield
OP was asking about Discovery 2....
They shared some wheels with the P38 Rangie, so looking if P38 wheels fit an L322 will also give you an answer.
Don’t know the answer myself, sorry. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #466159 26th Jan 2018 6:46pm
GraemeS
Australia
No, the D2 centering hub is smaller diameter.
Post #466163 26th Jan 2018 9:02pm
Tight777
GraemeS
Something rings a bell now that the RR wheels can fit a Disco but need a 'thing' (spigot?)
so they centre properly, and hence they don't work in reverse.
Post #466178 26th Jan 2018 10:36pm
As above... 322 wheels will fit a D2 using a spigot ring but D2 wheels won’t fit over the hub of a 322 unless the centres are milled out on a lathe... Thumbs Up
Post #466180 26th Jan 2018 10:41pm
Gunning
England 2013 Range Rover Autobiography SDV8 Baltic Blue
I was told a tdv8 couldn’t have anything less than a 19” wheel due to the calliper clearance on the front 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #466192 26th Jan 2018 11:06pm
Some compomotive 18” alloys will fit a TDV8 but most 18” alloys won’t sir Thumbs Up
Post #466194 26th Jan 2018 11:11pm
^ like these,
edit, wrong pic posted, thanks for pointing that out craig Wink
this is the pic i should have posted,
http://www.fullfatrr.com/forum/topic43217.html ... - .- -.
Post #466195 26th Jan 2018 11:19pm
^ them are 19” D4 wheels Stan Thumbs Up
Post #466199 26th Jan 2018 11:42pm
Ask me how i know Whistle Whistle Whistle
Post #466200 26th Jan 2018 11:43pm
verydisco
17'' BB6 performance fit td6s if that helps
http://www.fullfatrr.com/gallery/albums/us...G_6287.jpg l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #466210 27th Jan 2018 1:30am
