![]() | Home > Wheels & Tyres > Discovery 2 wheels to L322? |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I'd be worried about the load rating of the wheels - The L322 is a fair bit heavier than a Disco 2.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Edited: D2 wheels are not straight swaps, no. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
Depending on the wheel you might need different nuts , I just swapped some 18" that were available on the disco , they had black nuts but they didn't fit the 19" wheels which needed the chrome nuts |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7937 ![]() ![]() ![]() |
OP was asking about Discovery 2....
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2712 ![]() ![]() |
No, the D2 centering hub is smaller diameter. |
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 ![]() ![]() ![]() |
GraemeS
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
As above... 322 wheels will fit a D2 using a spigot ring but D2 wheels won’t fit over the hub of a 322 unless the centres are milled out on a lathe... |
Gunning Member Since: 28 Sep 2016 Location: Cornwall Posts: 237 ![]() ![]() ![]() |
I was told a tdv8 couldn’t have anything less than a 19” wheel due to the calliper clearance on the front 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Some compomotive 18” alloys will fit a TDV8 but most 18” alloys won’t sir |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35749 ![]() ![]() |
^ like these,
^ them are 19” D4 wheels Stan |
Ask me how i know |
17'' BB6 performance fit td6s if that helps
