I've read and reread so many posts and would just like a little advice.
Over night it goes lop sided, on start up sometimes it has a wriggle and levels up other times its a bong and Christmas tree dash board lights.
I can clear that with my OBD icarcraft reader, fault with K BUS error message.
I tried Craigs lift the wheel arch and listen for a hiss -no not that.
I put it into off road and left it over night as a double check for a leak, still up 10 hours later and level.
Drive off drop to normal height park up and less than 2 hours later it sits lop sided.
The selector still had red lights so I selected off road and up it went, drop back down to normal and it sits level.
Bit of a pfaff but works.
I've checked the height sensors are all connected and secure as should be. In the meantime I park in off road mode if I remember.
So the advice please. I guess it is the height sensor that is at fault and looks a dead easy replacement job. But when sitting lop sided it is front and rear so do both need replacing or what?
