![]() | Home > Technical (L322) > Upper Glove Box lid MY07+ |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
it does sound like its all out of sync...your battery reset suggestion might do the trick... ... - .- -.
| quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 336
Great will give that a try, I will follow the guide for the pyrotechnic battery disconnect thing etc. 2005 E60 M5
I have tried a battery off reset but to no avail.
maybe a loose wire behind the button/switch? ... - .- -.
Possibly, I've got the workshop manual and had a read through it for removing the glove compartment to get to the latch doesn't appear too bad although the switch is a little more tricky by the looks of things. I think I'm going to have to find a specialist to take it all to bits to see whats wrong.
why not prise the button out and have a look... ... - .- -.
Does it just prise out? I wouldn't want to risk damaging it further. Has anyone removed the button? 2005 E60 M5
Does anyone know which fuse might control the latches? Feed the switches? 2005 E60 M5
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Yes, it just pulls out. Use a credit card or similar to protect the dash and small screwdriver and pry it out.
Great stuff thanks for that.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Only Landroverr would ave a switch that needs programming |
Yeah, I don't think its the actuator either. Its just a solenoid.
Well that took the grand total of 9 seconds to remove. Jesus, looking at the LR manual its about 20 hours labor.
2012 are different dashes and instruments. The part No states from 2007 to 2009, so I would guess not. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
| All times are GMT |
