![]() | Home > Technical (L322) > Upper Glove Box lid MY07+ |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 ![]() ![]() |
it does sound like its all out of sync...your battery reset suggestion might do the trick... ... - .- -.
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 297 ![]() ![]() ![]() |
Great will give that a try, I will follow the guide for the pyrotechnic battery disconnect thing etc. 2005 E60 M5
I have tried a battery off reset but to no avail.
maybe a loose wire behind the button/switch? ... - .- -.
Possibly, I've got the workshop manual and had a read through it for removing the glove compartment to get to the latch doesn't appear too bad although the switch is a little more tricky by the looks of things. I think I'm going to have to find a specialist to take it all to bits to see whats wrong.
why not prise the button out and have a look... ... - .- -.
Does it just prise out? I wouldn't want to risk damaging it further. Has anyone removed the button? 2005 E60 M5
Does anyone know which fuse might control the latches? Feed the switches? 2005 E60 M5
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Yes, it just pulls out. Use a credit card or similar to protect the dash and small screwdriver and pry it out.
Great stuff thanks for that.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2230 ![]() ![]() ![]() |
Only Landroverr would ave a switch that needs programming |
Yeah, I don't think its the actuator either. Its just a solenoid.
Well that took the grand total of 9 seconds to remove. Jesus, looking at the LR manual its about 20 hours labor.
2012 are different dashes and instruments. The part No states from 2007 to 2009, so I would guess not. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
