Home > In Car Electronics (L322) > Ipod connector lead ?
philip600
Hi everyone, new member here. I've just bought a 2012 Westminster 4.4 & in the centre armrest instead of the usb / Aux socket I think should be there is just a plug. A neighbour has a RR Sport & he lent me a lead that he bought for his but the plug he connects to his car is the same ( female ) type connector that I have on mine so they don't fit together. I Googled the leads & they all appear the same as his, can you get a female to male adaptor or is something missing from my car ?
TIA, Phil
Post #467323 4th Feb 2018 9:03pm
mjdronfield
Without checking, the iPod connection is inside on the drivers side.... the usb socket is inside on the front side, a few inch down....
If that makes any sense?
Looking online they may both be at the front of the cubby.....I’ve only ever used the usb....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #467324 4th Feb 2018 9:07pm
the lead is a JLR standard lead.
I have one in my 2012, and it was in the car when I bought it. The lead is a 30 pin apple to JLR connector.
iPhones and pods wont connect via the USB though you could load a stick full of music. there are several non genuine ones on Amazon or you could ask Dan (duckworthparts) for a price.. There is nothing that can't be fixed with a hammer😜😜
Post #467336 4th Feb 2018 10:03pm
philip600
The USB / iPod socket is what should be there but all I have is a plug on the end of a cable which I suspect would have plugged onto the back of the missing socket. Question is, will I need to get the missing USB / iPod socket or can I get a lead that would plug straight into the socket I have ?
Post #467352 4th Feb 2018 10:58pm
Dolphinboy
I believe this is the type of cable you need (although u May want to pay more for a genuine article)
https://tinyurl.com/y77q32ph
Post #467390 5th Feb 2018 9:53am
philip600
Hi, thanks for the reply. The link you've sent is the correct cable if I had the LR USB / Ipod socket but mine is missing this socket so I am left with a female plug hanging out of the hole in the centre armrest which the same as on the end of the lead in the link i.e. both female so they won't plug together. I may need to replace the missing socket but was just wondering if you could get an adaptor the join the 2 female ends together ?
Regards, Phil.
Post #467416 5th Feb 2018 1:35pm
philip600
Unnecessary quote removed
That is the socket that is missing from mine so I'm left with a plug ( that I presume would normally connect into the back of that ? ) I just wondered if there was an adaptor that I could plug into my lead that would give the same as the one that is in the missing socket or if I'll have to replace the missing socket ?
Post #467417 5th Feb 2018 1:39pm
GGDR
Post a pic of what yours is like at the moment....
. Cheers, Greg
Post #467418 5th Feb 2018 1:49pm
philip600
This is the plug in the car
Post #467419 5th Feb 2018 1:53pm
GGDR
ok great.
Weird that you don't have the socket btw.
See what a few others think but I think you will need the socket and the lead.
You could always get the lead and see first.
Greg Cheers, Greg
Post #467423 5th Feb 2018 2:08pm
Yep you will need the socket and the lead. Other wise it’s a double female version of that plug and I’m pretty sure they don’t do one of those.....
the socket is available as a separate item. Part number LR021802 There is nothing that can't be fixed with a hammer😜😜
Post #467451 5th Feb 2018 5:37pm
philip600
Thanks for all the info & part number, that's a great help. Smile
Post #467456 5th Feb 2018 8:02pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I have more than one lead you can have Whistle
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #467463 5th Feb 2018 8:48pm
