![]() | Home > In Car Electronics (L322) > Ipod connector lead ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Without checking, the iPod connection is inside on the drivers side.... the usb socket is inside on the front side, a few inch down....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
the lead is a JLR standard lead.
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 ![]() ![]() |
The USB / iPod socket is what should be there but all I have is a plug on the end of a cable which I suspect would have plugged onto the back of the missing socket. Question is, will I need to get the missing USB / iPod socket or can I get a lead that would plug straight into the socket I have ? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
I believe this is the type of cable you need (although u May want to pay more for a genuine article)
Hi, thanks for the reply. The link you've sent is the correct cable if I had the LR USB / Ipod socket but mine is missing this socket so I am left with a female plug hanging out of the hole in the centre armrest which the same as on the end of the lead in the link i.e. both female so they won't plug together. I may need to replace the missing socket but was just wondering if you could get an adaptor the join the 2 female ends together ?
Unnecessary quote removed
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Post a pic of what yours is like at the moment....
ok great.
Yep you will need the socket and the lead. Other wise it’s a double female version of that plug and I’m pretty sure they don’t do one of those.....
Thanks for all the info & part number, that's a great help. |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I have more than one lead you can have |
