![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
Just the interior of the inlet manifold......a small job, but very dirty.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
160 dmb,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35822 ![]() ![]() |
it appears that i have been honoured with this problem..
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Mine was done under LR warranty. What do I put here then? |
interesting....how did you present the problem/details to the dealer ? ... - .- -.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
In the old days Stan this was a corrosion preventer that all Range Rovers had so no corrosion underneath
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Bummer. How many miles are you at Stan?
I just explained the symptoms- car stank of hot oil after use ... ... the longer the run, the greater the smell. What do I put here then? |
Has any oil got into the coolant ? or the V at the top of the engine?, or is more likely just the β0β rings ?
morning chaps...
Sorry, Stan ... that's all I told them - was all I knew.
thanks G, i have LR assist coming tomorrow morning so hopefully the tech will know the proper 'wording' of the problem... ... - .- -.
You certainly want to hope they're more technical then me, Stan |
well LR assist have come and gone and the chap confirms that there is an oil leak at the near side rear of the engine block..he didnt get any mirrors or endoscope out so i'm sure what is leaking but he thinks its most likely the oil seals..
