![]() | Home > Maintenance & Mods (L322) > 2002-2005 M62 PCV Valve - then it went a bit wrong! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
if the seals are new i wouldn't worry, if you have the metal inserts in place then that should prevent over tightening, you are sure the seal is sitting centrally and if it is the corner near the half moon cut outs that the seal is sitting either side of the half moon?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2279 ![]() ![]() ![]() |
Thanks, the rubber grommet how tight were they for you? Could you place the ring on the top then bolt through by hand? I had to use pliers/vice as so tough and Un rubbery... Current stable:
As long as they are not brittle you will be ok, they are quite tough as they will be heated up to fairly high temperature. If you are worried but a Febi one to compare. Try leaving one under the cam cover trim for a journey and then see how tough it is.
They are all brittle and cracked at the bottom when the bolts were pushed through. I can feel the semis are on it’s just that bit of gasket that’s squeezed out I worry about but maybe i shouldnt as it’s just over compressed now I - this is at the top back.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Looking to do mine soon so following this with interest, but am I right in believing that the rocker cover bolt hole rubber seals are about £8 each!! ______________________________
Are you sure that isnt sealer squeezing out, you shouldn't be able to crush the seal that far as the metal liners / shoulder on the nuts in the rubber grommets should make it impossible i would have thought. i put my bolt seals into boiling water first to soften them up or they are very difficult to get over. i did mine in winter.
I was looking at Febi on eBay, my fault should have looked at island 4x4 and others first |
I like Britcar site as they show you alternatives but i have also purchased them from Island 4x4 as well.
You’re probably right but in the description it says for one. Be it one or one set I dont know but I’ll be messaging them for clarification.
I’m not sure the pic look and feels like gasket... Current stable:
I took the turbo off my mates TD6 today as the forecast said sunny, got it off ok and then about 1/2" of sleet and snow turned up, nice.
I pretty much did that all the other week it seemed to have just crushed and wouldn’t reshape I’m just paranoid it might start leaking oil and I wouldn’t realise then I’ll run out but I need to get over it I suppose Current stable:
Well guess what.... big puddle of oil under the car today and it looks like the gasket may have split where it over compressed what a joke. Typical the gaskets were from bmw and the grommets lr and even though the grommets were at fault guessing I have no recourse for a replacement due to different vendors. Not to mention it being a third time the cover is coming off. Tbh I’ve had enough of this particular job and think I am going to pay an Indy to do it, I imagine it should be under £150 with a new outer gasket just for the one bank and to not waste another Saturday repeating myself I’d pay that... may even get them to do the pcv if they are reasonable. Current stable:
Sorry I missed this, how did you get on ? |
