Home > Wheels & Tyres > Wheel options? 20 21 22"
Nelzuk
England 2013 Range Rover Autobiography SDV8 Santorini Black
Picked up my first FFRR yesterday from Land Rover Huddersfield, its a , 13 plate AB Sdv8 in Black with 22" alloys. Amazing machine but after a few hours driving around in my local area, I am noticing the very harsh ride on the 22s Shocked My test drive must have been on much better roads than where I live.
So My question is if I dropped down to 21" is there much difference or is it 20s I need to be looking at, if I change the wheels at some point?
N
Post #468100 11th Feb 2018 12:46pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
IMHO, 20" with 255/55 tyres are probably the best combination. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #468105 11th Feb 2018 1:22pm
With each drop, you’ll get a little more comfort - but a little more roll on roundabouts and corners.
I tried all 3 and as I’m mostly motorways and fast A roads, prefer 22’s - and they look better IMHO Thumbs Up
Post #468118 11th Feb 2018 3:27pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
20" is best for comfort and looks like it's meant to be. 22's are harsh and more likely to suffer pothole damage, and some might say they look too big. Wink
275/45/20 on my FF... 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #468135 11th Feb 2018 5:57pm
Nelzuk
Thanks for the replies chaps, I must say I would like to hang on the 22s as they do look great.
On another note I think I could be confusing the fact that I seem to have a knocking from the front suspension, that I was blaming on the low profile tyres. Its just a small knock on rough slow surfaces, I,m going to take it back tomorrow and give them some stick...
Post #468168 11th Feb 2018 8:17pm
Vogue
Check your pressures in the 22's, I have got both 22" and a set of 20's with off road tyres - the 22's are fine as long as they are not overinflated - I run mine on the light load pressures and they are fine. You don't need the higher pressures unless you are fully loaded with 5 people and luggage. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #468177 11th Feb 2018 8:48pm
Early 405’s suffer with suspension issues so make sure the dealer gets it right for you otherwise you will be driven MAD by rattles, knocks and a floaty feeling ride! If you need to pay for these then its VERY EXPENSIVE!!!
Post #468236 12th Feb 2018 1:54am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi you may have read my later thread and issues I am hav8ng with some new Pirelli’s. Out of interest is your car on Pirelli’s or contis ? Regardless definitely agree regarding ensuring right pressures. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #469122 17th Feb 2018 11:58pm
Nelzuk
Hi , I'm on contis. I have had the car in this week and had some bits replaced and it now drives great, out of interest whats PSI for light road use?
Post #469146 18th Feb 2018 11:15am
CMJ
33 psi front 36 rear. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #469148 18th Feb 2018 11:23am
Bill
Daft question
Can anyone recommend a half decent tyre pump/pressure gauge. In the past have bought the halford type and they seem to fall apart after one blow- & I have severel skeletons in my garage.
Ta very Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #469175 18th Feb 2018 4:25pm
ahbeddoe13
United Kingdom 2013 Range Rover Autobiography SDV8 Mariana Black
On my sport I was advised by a LR Master tech to change my tyres (when due) to a 275 45 20 instead of a 275 40 20. as it was a much better ride. It also fills the arch more which could work for the 22's although I have not tried that with my 405........ it could make it wallow a bit more.
I am looking for a winter tyre option for my L405...do I get a 22" winter tyre or buy a set of smaller rims?
Post #471225 5th Mar 2018 7:48pm
Some other threads already - I run 275 40 22 Conti Winters
There's a theoretical advantage in going to 20's and having slightly narrower 255 tyres - but no real benefit in taller sidewalls.
Post #471227 5th Mar 2018 8:06pm
the 405 suspension is tuned to run the 22" rims, the 322 is not. It was only ever meant to run 20", which is why the ride might seem harsher on 22" in the 322 than it would on the same rim combo in the 405.
Personally I prefer the look of the 22" on the 405, but think they can look a bit big on the 322. 21" look good, but personally I run 20" with a 255/50 20 which is mfr standard. Its the best compromise on the 322 between looks and ride.
There are now an increasing number of tyre options in this size as Jag and Audi also have cars needing 255/50/20's so you can now get Scorpion Verde in this size where previously they were only available in 255/55. There is nothing that can't be fixed with a hammer😜😜
Post #471235 5th Mar 2018 8:44pm
