![]() | Home > Technical (L322) > Steering Column Motors |
| Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16
It’s possible that there is a problem but It could be they have been turned off. I switched mine off as I didn’t fancy motor failure. You will need decent diagnostics to access the settings though.
| peterweston1 Member Since: 07 Dec 2017 Location: Suffolk Posts: 8
Hi Jon
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Not sure if the foxwell is capable of doing the job.
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
It's worth taking the steering wheel cowl off before spending any money.
Best to fill in your vehicle profile too so we know how best to help. |
Thanks Simon, I will check that out. Regards |
Sure, will do! Regards |
Interesting, never thought of that! |
No problem and best of luck sorting it out...... ______________________________
Unnecessary quote removed
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560
On a BMW era L322 its fairly common for the motors or the mechanisms to fail on these and the older these cars get the less likely they will continue to work. An new column these days is thousands. If you can hear the motors running (I assume you can't) and the column isn't moving there are fixes but if you can't hear the motors then as previously suggested, take the cowling off and check if there is power to the feeds. Current Fleet:-
Thanks Nicksaab
| All times are GMT |
