Home > Technical (L322) > Steering Column Motors
peterweston1
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Both motors on my steering column don't work so is that usual or could it be something else that has failed? I have power to the driver seat so Fuse 20 should be good. Any help would be appreciated.
Peter
Post #468269 12th Feb 2018 11:57am
Gunni
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
It’s possible that there is a problem but It could be they have been turned off. I switched mine off as I didn’t fancy motor failure. You will need decent diagnostics to access the settings though.
Jon
Post #468318 12th Feb 2018 8:37pm
peterweston1
Hi Jon
Thanks for the reply. I didn't know you could disable them. So I was thinking of getting a decent diagnostic tool like the Foxwell NT510 so I assume I can get to the settings from that. Are the settings also available for the on board computer settings?
Regards
Peter
Post #468383 13th Feb 2018 8:28am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Not sure if the foxwell is capable of doing the job.
The weapon of choice for most forum members is the IIDtool from GAP Diagnostics. Expensive but will pay for itself many times over and the customer service is second to none.
Have a look on their site and look over the user manual, you’ll be amazed at what it can do.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #468385 13th Feb 2018 8:45am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It's worth taking the steering wheel cowl off before spending any money.
It could be that someone in the past has just dis-connected the wiring plugs to the motors - either to hide failed motors OR prevent failure. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #468387 13th Feb 2018 8:47am
UK Marine
Best to fill in your vehicle profile too so we know how best to help. Thumbs Up ______________________________
Simon
Post #468388 13th Feb 2018 8:50am
peterweston1
Regards
Thanks Simon, I will check that out.
Regards
Post #468389 13th Feb 2018 8:51am
peterweston1
Sure, will do!
Regards
Post #468390 13th Feb 2018 8:52am
peterweston1
Interesting, never thought of that! Very Happy
Post #468391 13th Feb 2018 8:53am
UK Marine
No problem and best of luck sorting it out...... ______________________________
Simon
Post #468392 13th Feb 2018 8:53am
peterweston1
Unnecessary quote removed
Hi Simon
Can't see on the GAP site that there is a setting for the steering motors either. Just have to do a bot more digging. Confused
Post #468403 13th Feb 2018 9:54am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
On a BMW era L322 its fairly common for the motors or the mechanisms to fail on these and the older these cars get the less likely they will continue to work. An new column these days is thousands. If you can hear the motors running (I assume you can't) and the column isn't moving there are fixes but if you can't hear the motors then as previously suggested, take the cowling off and check if there is power to the feeds. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #468436 13th Feb 2018 1:26pm
peterweston1
Thanks Nicksaab
Sound like the easier starter for 10.
Regards
Post #468438 13th Feb 2018 1:33pm
