Home > Technical (L405) > PHEV - looking for info on charging |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Your dealer needs to get his act together.
13th Feb 2018 8:07pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
It is correct that it is nobody will recommend it unless there is installed some extra protection in your home electrical system, because a fully charged battery can under some conditions return current back in the grid. I can't explain the technical stuff around this, ask an electrician.
13th Feb 2018 10:19pm |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 277 |
A fully charged battery will NOT return current back to the home system! In the case of a charger that connects to a 13A socket outlet, it will NOT draw more current from the mains; the specifications of the charger are the limiting factor on current draw.
14th Feb 2018 9:19am |
I see that the previous poster is a bit sceptical to what i wrote. You can read more on the subject for example on this link: http://www.connectingindustry.com/electric...ents-.aspx
14th Feb 2018 5:29pm |
^The referenced article is discussing an entirely different situation, where a fault condition (actually it covers a variety of fault conditions) has occurred. You are no more or less likely to suffer such fault conditions whether you have a 13A plug in charger or a fixed installation charge point. So, going back to the OPs original question, a fixed charge point is better because it will provide a higher output to make charging times lower. They are also neater and more convenient to use. |
14th Feb 2018 9:36pm |
