![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6835 ![]() ![]() ![]() |
^ I don't think that's possible. On a car of your age, the only option for DRL is the level of main beam as a %age of maximum. Got - 2017 SDV8 Autobiography in Loire Blue
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
ah that sucks, the previous owner had left the bulb disconnected.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Just found this thread, just commenting so I can follow it, some good questions and answers! Current: TDV8 (3.6) RRS HSE
ChuChuRitzy Member Since: 14 Feb 2017 Location: South Yorkshire Posts: 24 ![]() ![]() ![]() |
EGR valve position bank 2 seems to always be at 0, despite the commanded values telling it otherwise
SilverSpanner Member Since: 28 Jun 2017 Location: Hamilton, South Lanarkshire Posts: 17 ![]() ![]() ![]() |
Bit of a long post! Bought a FFRR 2012 and when I got it home there was 2 slow wiper settings and 1 fast when operating the wipers, the windows went up and down using lazy mode with the key and all the door locks opened remotely. Since plugging in RSW, some strange things have started to happen. The wipers worked as they should for about 6 weeks and have now gone to delay, delay and slow as the three positions of the switch. The door locks - drivers door opens with one press of the remote and all doors open7 with two presses. Pressing and holding the remote can be used to open all windows and sunroof, but the same operation won't close any of these items. The engine can be started up without foot brake application - it used to require the foot brake to be pressed before starting.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
on the GAP web site you can see from the drop down menu what the iidtool is capable off,
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
My IID tool arrived yesterday.
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 ![]() ![]() ![]() |
I can’t answer your other questions, but I do know that the CCF upload not completed error is a quirk that Pat from GAP is aware of. It definitely uploads the changes fine. I guess they’ll fix on the next update Chris |
That’s good to know.
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Here's another IID tool oddity. Applies to L322's from 2010-2012 I think, and relates to the power fold mirrors. There seems to be three settings, as follows:
i've found a benefit of the folding mirrors is that it is a visual confirmation that the doors are locked.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
An even bigger benefit is that it fits in my garage with them folded but not when out in the driving position.😎😎
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Do you think exit from the rear or the sunroof? P525
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
Hi, Do you mean setting 2 folds the mirrors every second door lock or as in two pushes of the button (superlock i think they call it) 2010 TDV8 Autobiography Past - 02 & 03 TD6 And an 1984 Classic GAP Diagnostics |
