Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 14 of 38 <123 ... 131415 ... 363738>
Aleksandr797
United Kingdom 2012 Range Rover Vogue SE TDV8 Bonatti Grey
Guys,
Thank you all for this post and information. My RR had an oil in the coolant and smell of oil from the heater. Local garage quoted £400 for labour to replace oil cooler. Price for cooler was much more than price from Dan (Duckworth parts). I have bought cooler and gaskets from Dan and today replaced gaskets only, as cooler seems to be ok. Gaskets between two cooler parts were split and everything around was covered in oil. O-rings were also replaced. Job itself it's easy, from start to finish took me about 3.5-4 hours, but I have spent more than an hour cleaning manifold from sludge.
Thank you all for the info and especially Nino for the instructions.
Very glad that I have joined this forum Smile
Post #469104 17th Feb 2018 10:26pm
nino_nino
Post #469108 17th Feb 2018 10:35pm
what oil does the oil cooler cool, engine or auto box? ... - .- -.
Post #469303 19th Feb 2018 11:38am
GraemeS
Australia
Engine oil. The gearbox oil cooler is oil to air.
Post #469308 19th Feb 2018 12:01pm
thank you G... Wink ... - .- -.
Post #469309 19th Feb 2018 12:02pm
Baltic Blue
You beat me to it Graeme, the main engine oil filter feeds into the cooler as per picture,
Post #469312 19th Feb 2018 12:16pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Just got mine back from garage, 4th attempt at fixing the oil leak, so far they have replaced the oil cooler, something else and now the turbo hose...still smells of burning oil but maybe residual from the leak..luckily still under warranty...
and they lent me a brand new E-Pace, nice car but not a patch on the Range Rover.... I need more help than most...sorry !!
Post #469365 19th Feb 2018 7:00pm
Sunseekertom
Hello!
My TDV8 Which has disgust done 71000 has just started leaking oil on the driveway and I can smell oil when hot.
I live in Torquay Devon. Can anyone recommend a good independent down here that could help?
Thanks in advance!
Post #471118 5th Mar 2018 11:06am
Kinger
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I just noticed some oil drips on the last remaining patches of snow today, took a look and feel down the back of the engine, sure enough i have an oily hose end, ordered the o rings up , hopefully, i have time to do it before the weekend.
As always, this forum is priceless when looking for answers, well done everyone..brilliant help!!
Not sure about Torquay but Causeway 4x4 are right on Jct 23 of the M5 only about a 35 mins drive if you cant find anyone closer
Cheers
Mike
Post #471181 5th Mar 2018 4:39pm
dirtymonkey38
I now have this problem too, smoke coming from under the bonnet and stinks through the air vents (no smell with air recirculation on).
Got my viton O-rings today so went out for a look when I got in from work to try and locate the pipe. Engine obviously far too hot to do anything with and i wasn't able to locate the pipe I'm looking for with confidence. Latex gloves got a good covering of out while I was having a feel around and also might have oil around what I think may be the oil cooler. I will order the two gaskets and replace them.
I would like to remove the intake for better access to both, is this straight forward enough? Ive had a look for a workshop manual in the Wiki but cant find one for my year (2011 4.4 TDV8). Can anyone point me in the direction for a download of the workshop manual or a "how to" for the intake (I have searched) Very Happy 2011 RR Autobiography 4.4 TDV8
Post #471364 6th Mar 2018 6:07pm
Baltic Blue
The 2010-12 Workshop Manual is only available to members who have been active contributors for over 12months and with over 100 posts. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #471368 6th Mar 2018 6:40pm
dirtymonkey38
Fair enough, i'll have to go with the ham fisted approach haha. 2011 RR Autobiography 4.4 TDV8
Post #471369 6th Mar 2018 6:43pm
dirtymonkey38
If I get down to the oil cooler will it be obvious if its cracked/knackered? Im hoping its just my oil feed pipes that need the o-rings swapping and its just residual oil elsewhere. 2011 RR Autobiography 4.4 TDV8
Post #471370 6th Mar 2018 6:50pm
mpirie
It's not that obvious that the cooler is allowing coolant and oil to mix, unless oil starts to show in the coolant header tank.
Normally, the turbo feed pipes leak onto the bell housing.....and then drips onto the driveway. If it's the cooler, then the V will have oil in it, which will eventually fill up, then start running down the bell housing.
If you have a puddle of oil in the centre of the V under the cooler, then the gaskets will have given up or worst case, the oil cooler has cracked..
Gaskets are cheap, oil cooler not cheap.
Mike
Post #471379 6th Mar 2018 7:44pm
dirtymonkey38
Cheers, ill get the gaskets from Dan and do it in one go, assuming i can get it all apart. From a quick visual there looks to be a fair bit of stuff to remove/pipes/electrics in the way. 2011 RR Autobiography 4.4 TDV8
Post #471381 6th Mar 2018 7:51pm
