![]() | Home > Technical (L322) > P2264 - Water in Fuel Sensor Circuit - 2011 4.4 TDV8 |
Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11 ![]() ![]() ![]() |
**BUMP**
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 ![]() ![]() |
Fingers crossed someone knows the answer! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
I fear you are going to have to remove the fuel filter again and replace the sensor.
I judt found the sensor, dangling down in the engine bay, looks like it wasnt put back on
Mine is all attached and still throwing the fault |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Dominic, try unplugging cable and cleaning connector with el. cleaner and spraying some WD40, it cant hurt.
Thank you, will give it a try. |
JAS kindly worked on it today and it looked like the water fault was down to a fault fuel filter housing and sensor! All fixed now, happy days |
Mine just threw this message up again...RP on the dash but nothing happens to the car...
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Had similar at Christmas after I hit a bit of flooded road at speed - no restricted performance message, went away of its own accord. |
Unnecessary quote removed
After all my messing around with the water in fuel sensor wires and swapping the filters the RP message was coming up almost permanently so i spoke to Maltings about the Sensor wiring they sell for the TDV8 3.6, they were pretty certain it would be ok for my car and for the sake of a tenner inc delivery i ordered one late on Thursday afternoon, it arrived at 7:00 am on Friday!!! so a big shout out to them for excellent customer service.
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
Thanks for the tip I will try them today, as I have the same code and issue. |
The 3.6 tdv8 part turned up today. I will check the connections and install it at the weekend. |
