|  | Home > Technical (L322) > P2264 - Water in Fuel Sensor Circuit - 2011 4.4 TDV8 |
| Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11      | **BUMP**
|  23rd Feb 2018 12:52pm |
| OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61    | Fingers crossed someone knows the answer! | ||
|  23rd Feb 2018 3:52pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | I fear you are going to have to remove the fuel filter again and replace the sensor.
|  23rd Feb 2018 4:36pm |
| Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11      | I judt found the sensor, dangling down in the engine bay, looks like it wasnt put back on
|  23rd Feb 2018 6:47pm |
| OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61    | Mine is all attached and still throwing the fault  | ||
|  24th Feb 2018 10:41am |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | Dominic, try unplugging cable and cleaning connector with el. cleaner and spraying some WD40, it cant hurt.
|  24th Feb 2018 12:54pm |
| OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61    | Thank you, will give it a try. | ||
|  24th Feb 2018 3:01pm |
| OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61    | JAS kindly worked on it today and it looked like the water fault was down to a fault fuel filter housing and sensor! All fixed now, happy days  | ||
|  28th Feb 2018 8:23pm |
| Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11      | Mine just threw this message up again...RP on the dash but nothing happens to the car...
|  8th Mar 2018 3:47pm |
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2628    | Had similar at Christmas after I hit a bit of flooded road at speed - no restricted performance message, went away of its own accord. | ||
|  8th Mar 2018 6:43pm |
| OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61    | Unnecessary quote removed
|  8th Mar 2018 6:55pm |
| Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11      | After all my messing around with the water in fuel sensor wires and swapping the filters the RP message was coming up almost permanently so i spoke to Maltings about the Sensor wiring they sell for the TDV8 3.6, they were pretty certain it would be ok for my car and for the sake of a tenner inc delivery i ordered one late on Thursday afternoon, it arrived at 7:00 am on Friday!!! so a big shout out to them for excellent customer service.
|  10th Mar 2018 1:56pm |
| Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88      | Thanks for the tip I will try them today, as I have the same code and issue. | ||
|  14th Oct 2020 7:14am |
| Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88      | The 3.6 tdv8 part turned up today. I will check the connections and install it at the weekend. | ||
|  16th Oct 2020 4:43pm |
| Posting Rules
