Home > Technical (L322) > Cold Start
alangrig
Latvia
Cold Start
Dear Gents and Ladies,
I have changed all spark plugs (fitted original LR), but still my personal perception that something is wrong during star up at low temperature.
I would appreaciate hearing any thoughts on this https://vimeo.com/257082976
Regard,
Alex
Post #469752 23rd Feb 2018 8:29am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I would not be concerned with the time taken or ease of starting. At such low temps, I’d say that was very good performance.
I would be concerned about the amount of engine noise until the oil warms up a bit. Have you considered using a different grade of engine oil to cope with such low temps? I’m not an expert, but would have thought there were options. Of course, anything you choose will need to cope with normal operating temps as well, that’s where modern multi grade oils come in.
I presume you’ve changed *glow* plugs, not *spark* plugs. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #469753 23rd Feb 2018 8:44am
alangrig
Latvia
Dear Steveball,
thank you. Yes, you are right, LR changed glow plug. In regard to oil, I use oil Castrol Edge Professional C1 5W-30. Do you think this one might be an issue at low temperature start?
Post #469756 23rd Feb 2018 8:53am
steveball
5W-30 is the correct grade of oil specified by Land Rover for this engine. I'm not certain whether that Castrol oil complies with the Ford specification WSS-M2C913-B or WSS-M2C913-C, but that's what LR tell us we need. The TDV8 is a Ford-derived engine.
However, at extreme low temperatures (and I definitely consider -22C very low), I would be tempted to got for a 0W-30, which will be less viscous at cold temperatures, but remain the same viscosity at normal running temperatures. Whether that's worth doing will depend on how often you experience temperatures like this.
Someone who is expert in the field of oils (such as Opie Oils) might be able to give good advice. Someone in your country, who is used to dealing with very low temperatures might also have good knowledge to share.
That's the limit of my knowledge, I'm afraid. Current: 2010 Range Rover L322
Post #469764 23rd Feb 2018 10:10am
alangrig
Latvia
Steveball,
thank you. Usually we have normal temperature during winter season within the range +/-5 degrees. Only for a week we have around -15/-22. So 5W-30 should be fine.
Post #469775 23rd Feb 2018 12:23pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
when my starting got poor it was an injector losing pressure and since its was refurbed the starting is brilliant so my suggestion is get the injectors spill tested
Post #469792 23rd Feb 2018 1:53pm
alangrig
Latvia
bembo449,
thank you. In regard to injector, have your car ever experienced problems with injector under normal daily operation?
I am asking, because last Friday one of local indies checked all injectors. All of them operate within given range of figures and fuel consumption also within given range.
Post #470106 26th Feb 2018 7:17am
Wondered what engine we were talking about when you mention spark plugs.
Regarding low temperature engine oil. I know a guy on another forum who tests oil. He recommends the low temperature oil because they have to improve the oil quality to get it working at low temperatures, so it's better oil.
I don't think the oil has anything to do with the sound of that engine though.
Post #470107 26th Feb 2018 7:25am
nino_nino
Alex, may want to try some 2T oil. it will clean and lubricate full pump and injectors. I use 1/2 L on a tank full.
Nino,
Post #470142 26th Feb 2018 12:43pm
alangrig
Latvia
Hi All,
I've been advised to restart up the glow plugs around 3-5 times. Here is the results:https://youtu.be/hyKsW1ldGlM
Seems better, but still not smooth enough. I guess, all injectors should be checked.
Regards,
Alex
Post #470490 1st Mar 2018 8:41am
